Fuel pump relay - Mustang Evolution
Old 03-10-2011, 05:02 PM   #1
Jamesgt08's Avatar
Fuel pump relay
Ok im having trouble with my car not starting. It just cranks but no start. Battery works fine. Someone said it could be my relay and i cant find where its at. Ima change out my fuel pump tomorrow.
Jamesgt08 is offline   Reply With Quote
Old 03-10-2011, 05:05 PM   #2
The relay should be in the fusebox somewhere. Check the one under the hood.
'93 Cobra (Show) '86 Vert (DD)
93CobraGuy is offline   Reply With Quote
Old 03-10-2011, 05:11 PM   #3
There is a fuel pump cut off switch left side in the trunk. Make sure it is not switched off.
Alscobra is offline   Reply With Quote
Old 03-10-2011, 05:14 PM   #4
Ah dammit. The elusive shut off switch. Forget that thing every time!
Old 03-10-2011, 05:16 PM   #5
Jamesgt08's Avatar
I checked the switch in the trunk is is on. And i already checked the relay under the hood. The only thing i can think it is. Is my ccrm or my pump.
Old 03-10-2011, 05:28 PM   #6
Does the relay click when you turn the key on? If so, turn the key off for a few seconds. Have someone turn the key back to run while you hit the bottom of the gas tank. Sometimes that will kick the pump back on. That may also let you know if it's the pump.
Old 03-10-2011, 05:30 PM   #7
Jamesgt08's Avatar
Yea it clicks when i turn the key on. And ive tried hittin the gas tank too. Nothing.
Old 03-10-2011, 05:32 PM   #8
Pretty sure it's the pump anyway. Only other way to tell for sure is a test light. Good luck.
Old 03-10-2011, 05:40 PM   #9
Jamesgt08's Avatar
So the clicking noise coming from the ccrm is normal then?
Old 03-10-2011, 05:52 PM   #10
ccrm?
Old 03-10-2011, 05:54 PM   #11
Jamesgt08's Avatar
Constant control relay module.
Old 03-10-2011, 06:10 PM   #12
Just make sure you are touching the fuel pump relay itself. Other relays will click also.
Old 03-10-2011, 08:39 PM   #13
Jamesgt08's Avatar
Yea ima look at it tomorrow see wat i can do. Hopefully i get it running again.
Old 03-12-2011, 03:13 PM   #14
Jamesgt08's Avatar
I just finished changing my fuel pump and my car is running again im so excited.
Pruchased my Fuel Injectors and Fuel pump today Brent Pictures and Videos 36 12-14-2010 03:22 PM
fuel pump for v6 The Darkside Pre-2005 V6 Mustang 11 01-06-2009 09:27 PM
fuel pump?? Xx_1990GT_xX 1979-1995 Mustang GT 7 10-07-2008 06:37 AM
Fuel pump lowflyn Mustang Parts for Sale and Wanted 4 08-01-2006 08:12 AM
19LB Fuel Injectors; 190-255LPH Walbro Fuel Pump Brent Mustang Parts for Sale and Wanted 5 05-11-2005 11:04 PM
08:54 PM
