what the mechanic told me...need input - Mustang Evolution
Old 03-14-2011, 12:00 PM   #1
since i got the new ram clutch installed, he told me the shaking im feeling goin into gear is the stock aluminum flywheel i have.. because i have such a bettter clutch he said the aluminum flywheel may be warped and im feeling it since this clutch is biting down 10 times harder and that its not a big deal... am i being fed some bs or what? and do 99 cobras come stock with an aluminum flywheel?
nasty99 is offline   Reply With Quote
Old 03-14-2011, 12:07 PM   #2
Just got mine resurfaced. No chatter at all. Mine is aluminum.
Alscobra is offline   Reply With Quote
Old 03-14-2011, 12:09 PM   #3
Re: what the mechanic told me...need input
he glazed it or somethin but didnt cut it. im just worried cuz my exhaust is so loud i have things shaking loose, now i got this shaking on top of it
Old 03-14-2011, 12:12 PM   #4
That's an aluminum flywheel with a steel contact ring riveted to it. You need to get it resurfaced to get a true flat surface. And it's probably gonna kill that new clutch too.
Old 03-14-2011, 12:14 PM   #5
thats exactly what i was afraid was gonna happen. i was told that if he cut it, then it would be takin some credit off the flywheel and it wouldnt be as strong
Old 03-14-2011, 12:17 PM   #6
They are only good for a couple cuts. After that they need replacing. If it was never cut before, it should be good for one. Probably the mechanic doesn't have a machine to cut it. Not many places do have the right machine.
Old 03-14-2011, 12:20 PM   #7
I just happen to be lucky enough to have a family member with a flywheel machine. So I was able to see it be cut.
Old 03-14-2011, 12:26 PM   #8
SaleenFiend's Avatar
Sometimes new clutches chatter their *** off. Drive yours for a while to see if things change.
Old 03-14-2011, 12:29 PM   #9
fml
Old 03-14-2011, 12:32 PM   #10
explain chattering..
Old 03-14-2011, 12:37 PM   #11
Just what you are feeling. Slight slipping before full engagement due to uneven surface. Doesn't take much especially with a light flywheel.
Old 03-14-2011, 12:57 PM   #12
Good advice. Give it about 500 city miles. If it isn't gone by then there is a problem. When I put my centerforce df in it chattered a bit til about 300 miles in and it went away. And after it got super grabby. I stalled it quite a few times til I got used to it. Oem vs centerforce isn't even a game. What a great clutch. I will never buy anything but a df ever again. Great product
Built 2 Last TTT
Old 03-14-2011, 06:29 PM   #13
67mustang97's Avatar
Region: Vermont
Is it a stage 2 or stage 3? I had a stage 2 installed on my GT and it was very smooth no chattering at all. Every time you change a clutch resurface the flywheel. Or just do a flywheel upgrade while your in there.
Old 03-14-2011, 06:48 PM   #14
My centerforce was a dual friction. Not stage 2 or 3. And anytime you change the clutch you have to re-surface the flywheel or it may chatter or not mate properly because of leftover friction material on the flywheel. I just bought an aluminum flywheel so I gotta drop the tranny and install it. An aluminum flywheel lowers the rotational mass. Which means it takes less power to get spinning. I don't yet know how drivable it is but once it's in I will post on how it feels
Built 2 Last TTT
Old 03-14-2011, 06:56 PM   #15
Built 2 Last TTT
+1
93CobraGuy is offline   Reply With Quote
Mechanic Snapple750 1996-2004 Mustang GT 12 03-10-2011 12:00 AM
Told Ya Zim Brent The Bar 3 01-04-2008 11:27 PM
Gosh! Someone just told me my V6 was slow Brent The Bar 17 07-04-2006 09:14 PM
I told you my camera sucked! Ibanezplayer272 The Bar 9 06-20-2005 12:05 AM
He told me to put glasspacks on... wiarumas Pre-2005 V6 Mustang 7 08-20-2003 01:32 PM
11:54 AM
