Crack cover, not my fault! Who the hell doesnt torque the bolts down on IRS brace! - Mustang Evolution
Old 03-15-2011, 08:21 AM   #1
drusmith's Avatar
Send a message via Yahoo to drusmith
Exclamation Crack cover, not my fault! Who the hell doesnt torque the bolts down on IRS brace!
Well I found out why my differential cover crack. The previous owner installed the IRS brace either without (which I can't believe) or not torquing down the 2 outside bolts. One bolt was GONE!!! And thats how this happens! See pictures.
Approx $700 later with new LPW Cover = All better!
Still pissed!
ID:	24496   Click image for larger version
ID:	24498   Click image for larger version
ID:	24500   Click image for larger version
Name:	LPW cover.jpg
drusmith is offline   Reply With Quote
Old 03-15-2011, 08:24 AM   #2
Re: Crack cover, not my fault! Who the hell doesnt torque the bolts down on IRS brac
ouch.... but at least it was only 700 could have been worse
Old 03-15-2011, 08:26 AM   #3
That sucks man. Where you been dude? Are you changing the gear ratio while it's down?
Alscobra is offline   Reply With Quote
Old 03-15-2011, 08:28 AM   #4
yea you have not been posting much, get back on the board lol!
Old 03-15-2011, 08:39 AM   #5
drusmith's Avatar
LOL, sorry guys work has been crazy! Been traveling all over the Midwest for the last 3 weeks.
No changing gear yet. I also thought about going with solid rear end. To much $ for right now.
Old 03-15-2011, 05:34 PM   #6
Titus Wadicus
svtlx's Avatar
that was shiiiity!
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-15-2011, 05:53 PM   #7
They can back out on their own...
Had a buddy's start leaking, the bolts were all hand-tight all the way around. We had torqued them previously during the install. There is now lock-tite on all bolts.
Old 03-16-2011, 08:16 AM   #8
yea I probably should check mine...
Old 03-16-2011, 09:37 AM   #9
drusmith's Avatar
I will tell the shop to put lock tight on the bolts. I do not want this problem ever again. Specially with the new LPW cover! I have heard good things about this cover.
Parts from American Muscle arrive today. Car should be wrapped up Friday afternoon.
Old 03-16-2011, 09:39 AM   #10
drusmith's Avatar
thanks for the tip! Good to hear from you as well! you know I would have bought your car if you could have sold it at the time I bought mine! How did the house selling, buying thing go?
Old 03-16-2011, 11:02 AM   #11
not sure I would put lock tite on the bolts if its an entire new cover, I think he mainly ment the bolts you use for the diff brace~ good question though.
Old 03-16-2011, 11:11 AM   #12
drusmith's Avatar
Noted! I will see what the shop recommends. I dont believe I will need lock tight then.
Old 03-16-2011, 05:33 PM   #13
We're all settled down and doing well.
There's also 5 terminators right here in this little area now. We're having alot of fun lol.
Stage 8 bolts, but no bracket bolts? CreationNation 1979-1995 Mustang GT 1 04-13-2009 10:00 AM
crack in intake manifold eddie1 1996-2004 Mustang GT 5 12-04-2008 10:09 AM
Could be a crack head...... Brent Pictures and Videos 6 03-24-2008 07:37 PM
always knew lohan was a crack-wh0r3 Dark02Pony The Bar 16 01-07-2006 09:17 PM
Who ever does the polling at Fox Sports is on crack Brent The Bar 11 09-15-2005 05:29 PM
04:59 AM
