Underdrive Pulley Nightmare! - Mustang Evolution
Old 03-18-2011, 06:46 PM   #1
jjsg09's Avatar
Went to install my steeda underdrive pulleys and it turned for the worst. I hand tightened the install bolt but it wouldn't set the crank pulley so I just stuck a wrench on it to turn it twice.....it worked the crank pulley was set, but went to turn it back and it wouldn't. Well I did get it out but now the original bolt only will go half way In then gets hung up. I need help, I hope I didn't totally destroy the crank.
Old 03-18-2011, 06:50 PM   #2
You need to take the original bolt and match up a tap for it. Are the threads messed up on the bolt too. If not, find a tap that size and run it in the crank. Clean it out good and locktite the bolt on. You're gonna have to shop around for the right tap probably.
Alscobra is offline   Reply With Quote
Old 03-18-2011, 10:13 PM   #3
jjsg09's Avatar
Just the first two threads are a little rolled
Old 03-18-2011, 10:15 PM   #4
First 2 of the bolt? If so replace the bolt. It's important that you find the right tap to chase the threads in the crank. Should be no big deal after that.
Old 03-18-2011, 10:30 PM   #5
jjsg09's Avatar
Yea I will try but I'm thinking of just taking it to a dealer shop to have them do it. I'm afraid I will screw it up more. I think I just threaded the starter bolt too far.
Old 03-18-2011, 10:38 PM   #6
Taking it to the pros is always the best. That should be all they need to do on it.
Old 03-18-2011, 10:48 PM   #7
jjsg09's Avatar
I hope so....just hope they don't come back saying I'm screwed. I have a friend that works at a ford dealer. My starter bolt that steeda gave me is chewed up a bit on the end. Just makes me mad that the bolt they give you is a disaster waiting to happen.
Old 03-18-2011, 10:52 PM   #8
I doubt if you are screwed. Done that before. Once had to drill it out a little larger and tap a bigger thread in one. Use a bigger bolt. You should be ok. The right thread chaser is the only problem I see.
Old 03-19-2011, 11:55 AM   #9
doubletap4311's Avatar
Steeda clearly states to use the starter bolt to just get a few threads started. Then take it out and use the original. It also states if you screw in the starter bolt too far in, damage will result. Use a tap like stated above, then use a new bolt with locktite.
2002 Gt, 5 speed, BBK Cai, BBK 78 MM intake plenum combo, steeda UDP, steeda tri axe shifter, 4.10 Ford racing gears, Sct custom tune, raptor shift light.
doubletap4311 is offline   Reply With Quote
Old 03-19-2011, 12:48 PM   #10
jjsg09's Avatar
Well I know what it's states on the directions. The bolt itself has a tag that says it shouldn be tightened all the way down. I said up above the pulley wouldn't set and I just did two turns to get it set in and it striped out a bit. Didn't crank on it at all, just a cheap bolt!!!
Old 03-19-2011, 02:18 PM   #11
Your gonna be ok man. Just a matter of finding the right tool. **** happens. No big deal.
Old 03-19-2011, 04:26 PM   #12
jjsg09's Avatar
Thanks man
Old 03-19-2011, 11:15 PM   #13
jjsg09's Avatar
Re: Underdrive Pulley Nightmare!
HALLELUJAH ITS FIXED!!!
Wasn't stripped bolts, but the steeda bolt end broke off in the crank. Didn't realize it until I was able to get a mirror down there and angle it up so I could see in there. There was pieces of the bolt down in there and I was able to fish it out and et everything set back up and running. Ran it up and down the road and was fine.
Old 03-19-2011, 11:23 PM   #14
Great to hear it. I could see by your thread you were pretty stressed. Glad it was painless for ya
PETOM.biz TTT
Old 03-19-2011, 11:26 PM   #15
Good to hear! Congrats on the upgrade!
93CobraGuy is offline   Reply With Quote
Old 03-19-2011, 11:26 PM   #16
Glad to hear it man.
Old 03-19-2011, 11:30 PM   #17
congrats.....
Old 03-20-2011, 08:03 AM   #18
edross's Avatar
so how do you like it? can you feel any difference
2003 gt, sct custom tuned by VMP, k&n fipk, upr o/r x-pipe, dynomax turbo mufflers, mm c/c plates, mm full length subframe connectors, h&r race springs, bullit rims 18x10 rear 18x9 front, 4.10 gears, 20% tint, 9 inch shorty antenna
edross is offline   Reply With Quote
Old 03-20-2011, 03:50 PM   #19
jjsg09's Avatar
Yea the peddle feels a little lighter and the rpms from 2800-4000 feel a bit stronger. Just glad it's done!
underdrive pulley blackonblack Pre-2005 V6 Mustang 17 12-29-2009 08:46 PM
Underdrive Pulley mrjones3133 Pre-2005 V6 Mustang 11 08-10-2009 03:58 PM
Underdrive pulley obxdude018 Pre-2005 V6 Mustang 7 07-27-2009 04:07 PM
underdrive pulley STEVE Pre-2005 V6 Mustang 12 06-27-2004 02:20 AM
underdrive pulley 232SCstang Pre-2005 V6 Mustang 34 01-10-2004 06:48 AM
12:13 PM
