What should i do next???? - Mustang Evolution
Old 03-24-2011, 10:23 AM   #1
Redlsea's Avatar
I want more performance from my car and I'm not sure what to do next. Can anyone recommend something. I was considering cams or under drive pulleys or Maybe an aluminum drive shaft??
Redlsea is offline   Reply With Quote
Old 03-24-2011, 10:24 AM   #2
01StangGt's Avatar
Turbo or super charge it, under drive pulleys would be a good idea, what's all done to it?
01StangGt is offline   Reply With Quote
Old 03-24-2011, 10:25 AM   #3
01StangGt's Avatar
A guy lives a few house up from me has a fox body style with the 5.0 and has a turbo and it's a sweet toy the thing just rips around, I personally like super chargers.
Old 03-24-2011, 10:51 AM   #4
Redlsea's Avatar
my new mustang gt 4.6 2v
MODS
engine and powertrain
-bbk shortie headers
-flowmaster cat back exhaust system with off road 40 series mufflers
-bbk cold air intake
-bbk 78mm throttle body
removed the a/c compressor, lines, acumulator and condensor
-B&M stage 2 trans shift kit
-ford racing 3.73 gears
steering and suspension
-bbk lowering springs 2.5 inces front 3.5 rear
-energy suspension sway bar links and bar bushings
other
-HID headlights (12k)
-sequential rear signal lights
-front grill delete
-removed the hood scoop grill and made it into a fuctional cooling vent for the engine bay
Old 03-24-2011, 10:57 AM   #5
Brett Greene's Avatar
Always build your the motor first brah. Under drives and A drive shaft are cheap. Save up for a HCI swap thennn put some
Boost on it. Maybe through on some long tubes
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 03-24-2011, 11:28 AM   #6
Redlsea's Avatar
Re: What should i do next????
Is it true long tubes don't fit on an automatic??? And that's what I figured drive shaft then build the motor do a kenne bell 12-20 psi charger with Matched cams with roller lifters burg the latter part requires mucho denero
Old 03-24-2011, 11:34 AM   #7
Couldn't tell you bout the long tubes. But sounds like you know what your doing for the rest of it.
Old 03-24-2011, 12:49 PM   #8
all bolt ons will help and you listed some good ones, just research brands to get good setups
11:50 PM
