Squeak - Mustang Evolution
Old 03-24-2011, 11:18 AM   #1
Snapple750's Avatar
Squeak
Something in my engine bay is squeaking every time I hit a bump. It squeaks even when the car is off.
2 Legit 2 Quit
Snapple750 is offline   Reply With Quote
Old 03-24-2011, 11:20 AM   #2
Snapple750's Avatar
It sounds the same inside and outside the car.
2 Legit 2 Quit
Old 03-24-2011, 11:35 AM   #3
Redlsea's Avatar
I've had sway bar to frame bushings make that noise . I would hold the bushings while someone pushes up and down on the front end see if you can feel binding in the bushings. Hope this helps
Redlsea is offline   Reply With Quote
Old 03-24-2011, 01:03 PM   #4
Re: Squeak
shocks? push on the quarter panel (pop the hood and push on the strut tower so you wont dent the quarter panel.
Old 03-24-2011, 06:01 PM   #5
Snapple750's Avatar
Yep, it's only on the passenger side
2 Legit 2 Quit
Old 03-24-2011, 07:26 PM   #6
SaleenFiend's Avatar
Re: Squeak
Shocks it is.
Old 04-08-2011, 09:37 AM   #7
I haven't had this happen to me on my mustang but on my other car it did makes noises and I found that on the sway bar link the bolt wasn't completely tight so it was allowing movement and would cause it to make a noise but it could be your shocks and it probably is
Sick98Stang is offline   Reply With Quote
Old 04-08-2011, 10:50 AM   #8
wereKEV's Avatar
Re: Squeak
The 98gt I used to have made noise lioke that on mine it was tie rod ends yours sounds like shocks or a arm bushungs.
wereKEV is offline   Reply With Quote
Strange squeak dshaley77 1996-2004 Mustang GT 9 12-31-2010 12:25 PM
Engine Squeak bobby02V6 Pre-2005 V6 Mustang 3 11-27-2010 05:12 PM
Strut Squeak greenpony02 Pre-2005 V6 Mustang 14 03-09-2010 01:21 PM
A/C squeak Foxone General Mustang Discussion 9 11-22-2009 02:01 PM
Rear Squeak....Please Help!!! drzeusd Pre-2005 V6 Mustang 3 10-20-2003 02:44 AM
11:11 AM
