back from the dyno - Mustang Evolution
Old 07-31-2007, 04:32 PM   #1
maximus's Avatar
back from the dyno
So the tuner forgot to tell me, and I didnt even think about it, but I forgot to put 93 in the car b4 I got on the dyno. So as of right now, I only have the numbers for an 87 tune. I got a switch put in so that I can change it to 93 myself once I cycle the **** gas out. But on a mustang dyno with 87 I put down, 244/275. This is with jlt cai, bbk lt's, bbk x-pipe and a flowmaster cb. I was only able to get a print out of the graph. I will be taking the car back in a week or so to put it onto the dyno again to test out the 93 tune on the car and see what it puts down again. What do ya guys think?
maximus is offline   Reply With Quote
Old 07-31-2007, 04:37 PM   #2
bullitt482's Avatar
Re: back from the dyno
Not bad... You have an auto or manual?
01 Bullitt
Old 07-31-2007, 04:39 PM   #3
maximus's Avatar
manual...
Old 07-31-2007, 04:41 PM   #4
bullitt482's Avatar
Cool... Those numbers aren't too far from what a Bullitt puts down. I think with the 91 tune you should definately pick up some more power.
01 Bullitt
Old 07-31-2007, 04:45 PM   #5
I think you should send me your file.
Old 07-31-2007, 04:57 PM   #6
maximus's Avatar
^ if I had it I would surely give it to you. and yea, there was a bullitt there that put down 27*/*** that had slp everything from lts, to the exhaust and a cobra intake on a 93 tune.
Im going back in a week or so, so I will try to get the files then.
Old 07-31-2007, 05:03 PM   #7
bullitt482's Avatar
Why would you swap to a cobra intake on a Bullitt??
01 Bullitt
Old 07-31-2007, 05:09 PM   #8
maximus's Avatar
well thats what the owner said. he told me that he had a cobra intake put on. I dont know much about the engines in these cars, so i couldnt really tell. but I know that dam thing was huge.
Old 07-31-2007, 05:49 PM   #9
Maybe he is preparing to run a whipple/KB/eaton and had easy access to a cobra intake. :dunno:
Old 07-31-2007, 06:16 PM   #10
maximus's Avatar
i asked if he was planning on going sced, and his response was, " no im keeping it stock" just another case of a guy with too much money. he had every upgrade in suspension you can have, the trac bars, new brakes, springs, calipers tower brace, and all the other stuff you could imagine," the whole suspension system is boxed out.". he said "it makes cobras look twice when he goes around turns." for a guy who was about 40+, he didnt rly know much, just how deep his pockets were. this is all good modding, but not with a car you are planning on keeping around the same hp/tq as I am making right now.
Old 08-01-2007, 04:58 PM   #11
bullitt482's Avatar
On second thought, does the the intake manifold off of a 4V motor even fit a 2V motor??
01 Bullitt
Old 08-01-2007, 05:31 PM   #12
Well, I say no, but, I also said a 3 valve head wouldn't fit on a 2 valve motor and it was stated I was wrong, so who knows.
Old 08-01-2007, 05:33 PM   #13
hottcobra's Avatar
if the 4 valve & 2 valve share the same block than they might have the same intake valley sprade
Old 08-01-2007, 05:43 PM   #14
bullitt482's Avatar
I wasn't implying the valley spread, but then again, with wider and taller heads to make room for the extra 2 valves, that would come into play also. I was talking about the position of the intake ports on a 2V compared to the position of the ports on a 4V
01 Bullitt
Old 08-01-2007, 06:02 PM   #15
hottcobra's Avatar
donno I'm new to the Ford engines. if you want answers on a GM LSX I'm your man
Old 08-01-2007, 06:55 PM   #16
That's why I didn't think 3 valve heads would fit on a 2 valve gt...the intake can't possibly line up.
Just like I wouldn't think the intake for a cobra would line up with GT heads.
But...I'm not an engine guru so I can't say for sure.
Old 08-01-2007, 08:00 PM   #17
maximus's Avatar
oh yea, and he the guy said he put in a spec 3 clutch.
Old 08-01-2007, 08:04 PM   #18
hottcobra's Avatar
so Rob, how long do those Spec stage 3 chutches last
Old 08-01-2007, 08:31 PM   #19
In a bullit? probably forever...in a modded cobra with my driving habits...about 2 years or 20k miles.
Old 08-03-2007, 04:24 PM   #20
bullitt482's Avatar
Dam man... Our stock one lasted over 70 and still had some left when I went ahead and replaced it due to the TO bearing... And that was powershifting it all along... Sounds like we have a clutch rider JK
01 Bullitt
Old 08-03-2007, 05:29 PM   #21
maximus's Avatar
dont jk it, its prolly true.
Old 08-03-2007, 05:43 PM   #22
Hmm....no, not a clutch rider...just an abuser.
Old 08-05-2007, 07:11 PM   #23
Thomas91169's Avatar
heads and intakes for different valve amounts do not go hand in hand.
im pretty sure if you go with a 4v heads, you need the 4v intake as well. same goes with 3v, 3v heads use 3v intake, 2v heads use 2v intake. because of the actual size of the head, the mating variances are different, ports are designed different, etc.
as far as i know, you can fit any modular head on a modular block. getting it to work right is a different story (especially when it comes to the 3v and their vtec stuff).
-Thomas-
Old 08-06-2007, 04:26 AM   #24
maximus's Avatar
he didnt say anything about heads, just that he had a cobra intake. it didnt look all that new tho. is it is it possible that he used a pre 99-04 cobra intake?
Old 08-06-2007, 08:08 AM   #25
my stock clutch is still fine at 52k miles... I hope it stays that way lol... I have thought of just getting it over with and having it changed when I pulley/tune... along with a cooling mod while Ive got the tranny out but i dont feel like pulling the tranny myself... and I dont have the time to wait on it if I let someone like amazon do the work... and that will be about 1500 more dollars I need to spend on it.
Old 08-06-2007, 03:57 PM   #26
bullitt482's Avatar
It's still a 4V motor though....
01 Bullitt
Old 08-06-2007, 10:59 PM   #27
a bullitt? i thought those were just 2v's? that is the car in question (max said a bullitt with a cobra intake) right?
Ford Mustang Bullitt GT (2001)
-Thomas-
Old 08-07-2007, 04:29 AM   #28
maximus's Avatar
^ you would be correct my good man.
Old 08-07-2007, 09:35 AM   #29
bullitts are just GT's with a different upper intake and a couple other little things... pretty much a stock GT.
Old 08-07-2007, 11:55 AM   #30
KrazyPony's Avatar
I believe the intake, and suspension and mainly a little dress up.
KrazyPony is offline   Reply With Quote
Old 08-08-2007, 01:01 PM   #31
Herbstang's Avatar
Correct !!! alum intake, hi-flow mufflers and twin-bore throttle body
Old 08-08-2007, 04:57 PM   #32
bullitt482's Avatar
You all missed my point.. But I was vague You guys do know that I drive a Bullitt right???
I was talking about this statement. A pre 99-04 cobra intake is still coming off of a 4V motor... So it wouldn't matter if the intake came off off an 01 Cobra, or a 96 Cobra, it's still coming off of a 4V motor.....
01 Bullitt
Old 08-08-2007, 04:59 PM   #33
bullitt482's Avatar
Brembo rotors, PBR calipers, Twin 57 mm throttle body, Cobra alternator, Cobra mufflers, subframe connectors, Bullitt Springs, Tokico Shocks/Struts, Aluminum intake..... But yes, performance wise, very close to a stock GT.... Oh and they did come in a Dark Highland Green that was not offered but on the Bullitt.
01 Bullitt
Old 08-09-2007, 12:53 PM   #34
yeah im sure we were all like "wtf is bullitt talking about? he either must be confused or we are just tripping!"
-Thomas-
Old 08-09-2007, 01:08 PM   #35
Send a message via MSN to 1996stang Send a message via Yahoo to 1996stang
I wouldn't dare ask you too waste your breathe on such old technology
2004 mach 1 stock and staying that way.
1996stang is offline   Reply With Quote
Chevelle went back on the dyno hottcobra General Car Discussion 23 05-10-2009 10:38 AM
Got my car back from the dyno shop..... ricklmesa Pre-2005 V6 Mustang 4 02-16-2006 09:27 PM
On the dyno: MarkuzLS1 Pictures and Videos 34 04-29-2005 05:04 AM
NE DYNO DYNO DAY 11/8 BlueDonkey Regional Mustang Discussion 9 11-13-2003 01:51 PM
Going to Dyno Danger Dude Pre-2005 V6 Mustang 56 07-27-2003 12:23 PM
08:09 AM
