Clunking? - Mustang Evolution
Old 03-26-2011, 02:49 PM   #1
ColeJohnson's Avatar
Clunking?
Whenever I'm at a low speed I can hear something clunking/banging/scraping in the front end, not the engine though.
It's very loud and noticeable when I turn left. Sometimes it doesn't make the sound though, but sometimes it does.
Oh.. And I can feel it clunking. It's really noticeable. But at higher speeds, like over 20mph it goes away.
I thought tie rods, but would like other opinions.
2016 Comp Orange GT (current)
Old 03-26-2011, 06:21 PM   #2
01StangGt's Avatar
Check anything that has to do with suspension in the front, but tie rods sound like a very reasonable answer, just climb underneath and give it a good look, be surprised what you might find!
01StangGt is offline   Reply With Quote
Old 03-26-2011, 09:43 PM   #3
Re: Clunking?
So I just got off work and drove home... No sounds or clunking at all. Even when I turn sharply.
SO I started thinking about the days it does make the sound and stuff since it doesn't happen all the time. Maybe like once every two-three weeks it'll do it randomly.
The only thing similar with the occurrences was that it was mid-afternoon, a hot day, and my AC was on.
I RARELY use my AC, but how would an AC being on cause mechanical problems? And maybe something was overheating and not getting lubricated enough since it was so hot..?
I'm perplexed.
Old 03-26-2011, 09:43 PM   #4
Re: Clunking?
Oh, and I checked my tie rods and the steering and everything.. Nothing was visibly damaged.
Old 03-27-2011, 07:58 AM   #5
01StangGt's Avatar
Dang, ac would gave nothing to do with it I think, just when it does make the noise grab s friend and see if he can't stand near the car while driving and see if he can't pin point it, also hub maybe??????
Old 03-27-2011, 08:12 AM   #6
bbunt302's Avatar
You have to remember that having the AC and fans on puts both an increased electrical and mechanical load on the car.
One direct way the AC can cause problems is if the compressor seizes. This can also happen intermittently. I don't believe this would cause the sound you are describing though.
Scary stuff.
Old 03-27-2011, 12:49 PM   #7
So it's doing it again and it's really bad.
Old 03-27-2011, 12:49 PM   #8
Would it be a u-joint problem?
Old 03-29-2011, 11:25 AM   #9
Redlsea's Avatar
Try checking ball joints and sway bar to frame bushings
Redlsea is offline   Reply With Quote
Clunking noise when shifting Halyssvt 1996-2004 Mustang GT 7 03-08-2011 12:48 PM
Clunking sound coming from rear?? ricklmesa Pre-2005 V6 Mustang 6 11-14-2006 09:36 PM
drove to ATL, clunking the whole way..funny story tedness The Bar 32 09-27-2005 05:38 PM
05:04 AM
