Noise from rear end - Mustang Evolution
Old 03-29-2011, 01:00 PM   #1
Noise from rear end
Ok so here's the deal. My 02 gt is making more noise than usual. I know the TOB is bad so I'm going to replace that should I replace anything else while I'm in there? Also my car is making noise from the rear end on deseleration mainly in 3rd gear and below it sounds like a whining almost like a SC. I'm assuming it's either the gears or the bearings. But before I spend a bunch of money rebuilding the rear end I wanted to know if anybody had any other opinions on what it could be. Thank you
Mineralgreygt is offline   Reply With Quote
Old 03-29-2011, 01:35 PM   #2
Re: Noise from rear end
you may have just a fluid leak and its low. The reason it only does it on decel is when you apply the gas it puts pressure on the rear end and can raise the pinion angle etc etc. Many rear ends whine and its not hurting anything~ but get the fluid level checked and if it still does it you can pop the cover and see whats up.
For the clutch you should very much consider doing it all as it all has to come out either way.
clutch, flywheel, pressure plate, pilot bearing, throwout bearing, bearing retainer sleeve (if grooves are cut in it), check input shaft play for tolerance, check pivot ball stud, check shift fork (cheap so replace it) etc
Old 03-29-2011, 01:37 PM   #3
I'll do the fluid check and see if it changes Ty
Old 03-29-2011, 01:39 PM   #4
Also what should I be looking for when I pop the plate off
Old 03-29-2011, 01:56 PM   #5
Redlsea's Avatar
Dirty but no metal filings or metal chunks
Redlsea is offline   Reply With Quote
Old 03-29-2011, 02:00 PM   #6
yea, its good to clean it all out anyway. Could be the bearings going bad as well. Its not something you want to take out and put back in (gears/differential wise) as its got to be setup correctly.
Old 03-29-2011, 03:31 PM   #7
Thank you guys for answering my questions! I'm new to this site so its good to know we have knowledgable people on.
Old 04-03-2011, 06:16 PM   #8
So, my friend just did his rear end in a 99 3.8, to a ford racing carrier, and 4.10's, with an auto, and now has a squeeks. I suggested either a shim, bearing, or u-joint, or even maybe a crush collar. Any help or ideas what it may be. It happens when hes on and off the throttle, so obviously its not created by the torque. I had also told him, when those bearings are going out, it may not squeek, but rather have a grinding sond, cause they spin so fast. Any ideas???
Sent from my iPad using Mustang
6thGT is offline   Reply With Quote
Old 04-03-2011, 06:17 PM   #9
He had everything mapped, said his axle shafts looked good, and that he used the same bearings...all help will be great. Thanks.
Old 04-04-2011, 07:43 AM   #10
you cant just pop in gears you have to check backlash and many many other things such as wear pattern, I wish it was just as easy as bolting it up once they wear in a bad pattern its time for new gears.
Old 04-04-2011, 08:43 AM   #11
Did all that with gear paint...im not new A this at all...LoL
Old 04-04-2011, 08:59 AM   #12
good info, most just assume they slap right in, if thats not the case then not sure... they say some brands just whine more and Ford Racing sold out to Motive which are known to whine.
Old 04-04-2011, 09:01 AM   #13
I know he went with a FR carrier, but not sure about the gears...
Old 04-04-2011, 07:09 PM   #14
Redlsea's Avatar
That must be magical backlash measuring paint then because I'm a mechanic and know that you need a gauge : )
Old 04-05-2011, 03:08 AM   #15
Yeah, you do when you map it....
Front end Noise ?????? ArmyStangGT 1996-2004 Mustang GT 7 02-09-2009 08:13 AM
Rear End Noise Brent W. 2005-2010 Mustang GT 4 09-26-2008 07:00 AM
Rear end noise??? woodly1069 Pre-2005 V6 Mustang 2 04-30-2008 07:56 AM
Rear end noise bsmith782 1996-2004 Mustang GT 31 08-23-2006 08:46 AM
rear end noise + PS favor jimmy_beaner The Bar 10 06-21-2005 12:00 AM
01:29 AM
