lowering - Mustang Evolution
Old 03-30-2011, 07:10 PM   #1
lowering
I want to put a lowering kit on my 01 gt, would 2" all around be a problem, I am going to put 315-35-17 in the rear and 245-45-17 in the front is there going to be a clearance issue?
Sent from my DROIDX using Mustang Evolution
01KILLERGT is offline   Reply With Quote
Old 03-30-2011, 07:20 PM   #2
Brett Greene's Avatar
Well you cant out 315s on a 17inch rim.
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 03-30-2011, 07:21 PM   #3
Old 03-30-2011, 07:26 PM   #4
The rear rim size is 17/10.5
Old 03-30-2011, 07:28 PM   #5
Biggest you can put is 275 I believe. Need a 18 rim to do 315.
Old 03-30-2011, 09:20 PM   #6
2 inches is too much
PETOM.biz TTT
Old 03-30-2011, 09:26 PM   #7
Re: lowering
315/35/17 is about the only size that fits on the 17x10.5" rims. I have the exact setup on my car.
For 18x10's the suggested size is 295/35/18 or something along those lines.
I wouldn't go any wider than 275 on 17x9's, and no larger than 245 on 17x8's.
You should be fine with a 1.5"-1.75" max. drop with your wheel setup, but I would say 2" might be too extreme. I know people do slam them down that low, but any obstruction on the road larger than a pebble becomes an issue, along with driveways, speed bumps and bad roads.
Old 03-31-2011, 12:36 AM   #8
Re: lowering
I have 18x10 (305 tires) on the back with a one inch spacer and 2" drop also. I had to roll the fenders considerably cause they just chewed my tires up even without the spacer.
saif02gt is offline   Reply With Quote
Old 03-31-2011, 12:42 AM   #9
This is my springs like 2 hours after it was done. It settled down a little bit more. I'll post pics once it's driveable again.
Old 03-31-2011, 04:09 AM   #10
Tib
Tib's Avatar
Re: lowering
295/35R18's here...on the roush 1.5" factory lowered suspension...They fit and the 18's fit great, but the ride is bumpy.
2003 Roush Mustang GT Stage 2 Package - Current 'Stang
1998 Mustang GT - Previous 'Stang
Tib is offline   Reply With Quote
Old 03-31-2011, 05:08 AM   #11
That good to know
Old 03-31-2011, 06:03 AM   #12
Let us know what setup your going with but definitely 315 out back
Bullitt5036 is offline   Reply With Quote
Old 03-31-2011, 07:22 AM   #13
Re: lowering
2" is rather low, you will scrape on stuff. Mine is about 2 inches lowered and its ok~ (at the limit honestly) and I still scrape on stuff now and then. The wheels its all about offset~ should be ok
Old 03-31-2011, 07:52 AM   #14
I'm lowered about 2" all around with the pro-kit and I love it but scrape on some things.
Sent from my iPhone using Mustang
Old 03-31-2011, 10:01 AM   #15
Snstr99svt's Avatar
I'm lowered about 2" on H&R springs and I'm running 17x9 with 275/45r17 in front and 17x10.5 with 315/35r17 in back and I tend to bottom out quite a bit! The only problem I ran into was some rubbing on the inner fenderwell when I go over uneven roads and things that make my car bounce more than normal.
Snstr99svt is offline   Reply With Quote
Old 03-31-2011, 10:22 AM   #16
Re: lowering
just FYI if you are super low and you driver over a raised up man hole your K member can catch it and AKA frame damage.
Old 03-31-2011, 10:39 AM   #17
01StangGt's Avatar
You can put 315's on 17 rims, I wouldn't do it, I would stat with like 275's, that is a lot of rubber to turn. I actually seen 315 40 17's on a z28 today, is possible but it may be an issue, go with 275's, still looks bad ***
01StangGt is offline   Reply With Quote
Old 03-31-2011, 10:41 AM   #18
01StangGt's Avatar
And if you lower it go about 1.5 and get the camber caster to go with it, if not you will chew through tires like crazy
Old 03-31-2011, 03:29 PM   #19
ksrumbel's Avatar
I lowered mine 2". I have 17x9 fronts with 255/40 and 17x10.5 rears with 315/35. I have no problem with clearance in the fenders. The car looks nasty that low. I
ksrumbel is offline   Reply With Quote
Old 03-31-2011, 03:33 PM   #20
ksrumbel's Avatar
I would post pics if I new how. The only scrapping problems that I have is when the road has a crown, then my engine cradle will scrape a bit. It happens a few times but you learn to drive on the crown and avoid places where you will scrape. Go for it
Old 03-31-2011, 03:56 PM   #21
Snstr99svt's Avatar
That's a 17x10.5 with a 315/35R17 with the car being lowered 2" looks pretty good I think! Like people have been saying you will scrape a couple times but after a while you learn how to drive around things and pay a little more attention to the roads you drive! Good luck!
Old 03-31-2011, 04:51 PM   #22
ksrumbel's Avatar
That looks awesome. Mine looks the same way and I have the same wheels
Old 03-31-2011, 06:50 PM   #23
I got the roush springs and sruts it lowers the stang 1.5" with the 315 35 17s in the back with the sway bar kit, must say better than new.
Old 03-31-2011, 07:45 PM   #24
Topless04GT's Avatar
Re: lowering
ehem... IDK if I am too late for this thread or not.. But i will throw in my .02
I am 2.5"s dropped all the way around, and I am runnin 245 45 17s front, and 295 somethin 15s in the rear... i have no rubbing and I think my stance looks mean as hell... you should be 100% A OK... but I am not liable if you bottom out on ****... haha
My girl... ehh, cars never leave you! stick to cars!
My name is Josh, Whats yours?
Topless04GT is offline   Reply With Quote
Lowering my 04... 04SonicBlueGT 1996-2004 Mustang GT 22 10-23-2009 12:31 PM
Lowering?? Gt.Vert 1996-2004 Mustang GT 9 10-12-2009 07:12 AM
Lowering my 04 GT Talon 1996-2004 Mustang GT 13 07-15-2009 08:02 PM
lowering? 96cobra 1996-2004 Mustang GT 17 04-08-2009 11:04 AM
lowering? Kryptonite Mustang Audio & Video 6 10-23-2006 08:15 PM
01:17 AM
