Ok so I was driving home from work get to a red light take off in first switch to second but it won't go in gear so I try third, fourth, and fifth. Nothing. I couldnt seem to get it in any gear. Finally I get it in to third and get home like that. I didn't smell my clutch burning or anything so I don't think it could be that. My clutch pedal did feel a bit different. Mayb my clutch cable came lose?? I would really appreciate any answers.
The clutch cable has probably stretched enough not to allow the clutch to disengage properly. That would be my guess. If it broke, the pedal woud probably just be stuck on the floor.
I'm guessing that you're gonna replace the clutch, cable, quadrant, adjuster. I found a steeda kit on amazon. Cable/quadrant/firewall adjuster. $100. Good deal.
Can you start the car while in gear and clutch pressed down? What happens? Does it go in gear with the engine off? Need to answer some questions first.
I can start the car while the clutch is pressed down. I can pull it out of first with the car on. It will also go into gear with the engine off. Stock cable and quadrant.
Your clutch is shot. Clutch kit and cable kit will take care of it. You may just need a cable kit but might as well clutch it also. I'm sure that throw out bearing is bad also.
Yeah. The pressure plates wear out and the pedal gets stiff. It's kills the throw out bearings first. If you just replace the TOB and cable, it won't last long.
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
