rough idel - Mustang Evolution
Old 04-07-2011, 04:58 PM   #1
Supersnake4.6's Avatar
rough idel
IDk what's going on I took my car to autozone so they could pull a code and it did it said bank 1&2 are running lean I changed my mass air sensor fuel filter and no vacum leaks so idk it's not my injecters any ideas
Supersnake4.6 is offline   Reply With Quote
Old 04-07-2011, 05:18 PM   #2
It sound like I have a cam in the car it lops 6 to 800 rmps I am so confused on what it could be it's not my o2 sensors either
Old 04-07-2011, 05:49 PM   #3
Mine is doing that too. Ever since I put that stupid cai on. It's not throwing any codes tho
Old 04-07-2011, 05:55 PM   #4
Yeah I have a cai to so nothings wrong just to be sure becuase I have not drove it since
Old 04-07-2011, 07:53 PM   #5
Idk I have to figuar it out by 5 tmaro so anybody lol I need this done thanks
Old 04-07-2011, 07:59 PM   #6
Clean your idle air control valve
Hotttoast is offline   Reply With Quote
Old 04-07-2011, 08:02 PM   #7
Were is that
Old 04-07-2011, 08:03 PM   #8
USAF_stang's Avatar
Re: rough idel
yeah mine started that too...hopefully after I get a tune it'll smooth it out
USAF_stang is offline   Reply With Quote
Old 04-07-2011, 08:06 PM   #9
On the side of ur upper intake a 1" hose should plug into it and a electrical connector
Old 04-07-2011, 08:07 PM   #10
And if the valve is super easy 2 move it's bad
Old 04-07-2011, 08:08 PM   #11
LuvMyMustangGT's Avatar
I just ordered a cai for mine. And I'm sorry if this is a dumb question. Are there places that I can take it to get it tuned after we install it or do I have to buy a tuner which I can't afford right now.
LuvMyMustangGT is offline   Reply With Quote
Old 04-07-2011, 08:11 PM   #12
ksrumbel's Avatar
Replace your IAC (idle are control) it is on the front of the plenum sort of diamond shaped. I had the same problem and it fixed the problem. It's inexpensive and you should be able to get it at an auto zone
ksrumbel is offline   Reply With Quote
Old 04-07-2011, 08:11 PM   #13
You dont need a tune for a cai on a new edge cause they don't do anything.
Old 04-07-2011, 08:12 PM   #14
ksrumbel's Avatar
I really don't think a tune is absolutely necessary after a CAI if you are strapped for cash. It won't grenade your motor or anything but will wake it up
Old 04-07-2011, 08:13 PM   #15
USAF_stang's Avatar
Re: rough idel
gotcha. Wasn't sure if it had anything to do with the air/fuel ratio. I know on my bike it made a lot of popping and rough idle until I got it tuned after my racing intake was put on
Old 04-07-2011, 08:27 PM   #16
Awesome Thanks! My husbands going to love me. I ordered the cai and a chin spoiler today.
Old 04-07-2011, 08:38 PM   #17
What? A cai. Sorry bud but on a new edge it won't do squat. Compare a cai to the stocker. Same diameter pipe,same bends. Honestly save your money and just buy a high flow air filter and pull off the silencer. Free cai
Old 04-07-2011, 09:30 PM   #18
Ok I cleared my iac and WTF a loud humming noise was comming Crome my engin turned it off soon after what is going on????
Old 04-07-2011, 10:40 PM   #19
Jamesgt08's Avatar
My car was doin the same. I replaced my IAC and cleaned my throttle body and plenum and still did it. Then i replaced my cam and crank sensor and it works fine now.
Jamesgt08 is offline   Reply With Quote
Old 04-08-2011, 03:51 AM   #20
ksrumbel's Avatar
I think my post was unclear bud. My meaning was the tune will wake the car up but just isn't necessary after a CAI. I also don't believe a CAI will do much of anything
Old 04-08-2011, 03:53 AM   #21
ksrumbel's Avatar
Woah dude check to see if there is oil in it.
Old 04-08-2011, 07:47 AM   #22
Jamesgt08's Avatar
CAI dnt do anything. Thats why all i have is a k&n cone filter.
Old 04-08-2011, 08:30 AM   #23
SaleenFiend's Avatar
Re: rough idel
Replace your IAC (idle are control) if it continues to idle roughly after cleaning.[/QUOTE]
Ok I cleared my iac and WTF a loud humming noise was comming Crome my engine turned it off soon after what is going on????
What kind of humming noise? Is it coming from the internal engine? Pulleys? need more info. What did you use to clean the IAC and did you do it on the vehicle?
Old 04-08-2011, 11:16 AM   #24
wereKEV's Avatar
Re: rough idel
Excuse my stupidness but what the hell is a edge gt?
wereKEV is offline   Reply With Quote
Old 04-08-2011, 11:17 AM   #25
Must have meant New Edge (99-04)
Old 04-08-2011, 03:19 PM   #26
More from the pullys but j found the problom it a vacum leak I have a cracked intake manafold
Old 04-08-2011, 03:25 PM   #27
That makes sense. I guess I will find out tomorrow if mine is
Old 04-08-2011, 04:55 PM   #28
Re: rough idel
This couldn't be further from the truth. This is why so many people get CEL's and cars that don't run properly after installing a CAI or short ram intake.
for cars that use the MAF instead of the MAP sensor to determine fueling for the motor it is essential that the tubing surrounding the MAF have the same geometry of the stock intake tubing. If not, the ECU will not properly fuel the motor becuase the readings for grams per second of air entering the motor will be skewed because the geometry of the tubing has changed around the MAF. Basically it will think there is a different amount of air entering the motor than there really is because air will pass over the MAF differently becuase of the tubing geometry. People in the forced induction know this all too well in vihicles that are fueled by the MAF instead of the MAP sensor.
And to the OP, if you don't have the money for a tuner you will not have the money to get the car TUNED either as you will have to have the money to buy a tuner and take it to get TUNED which will cost you a few hundred dollars on top of the tuner.
ajpturbo is offline   Reply With Quote
Old 04-08-2011, 04:58 PM   #29
K...on a 05 sure...99-04 your wrong
Old 04-08-2011, 05:01 PM   #30
Joshy's Avatar
Get em.
www.petom.biz
Joshy is offline   Reply With Quote
Old 04-08-2011, 09:08 PM   #31
Snapple750's Avatar
Opposite for me, mine drops to like 300-500 rpm, and then up to 750-800 rpm whenever I give it gas with the clutch in or in neutral. Before it idled at 900-1000 and dropped a little
2 Legit 2 Quit
Snapple750 is offline   Reply With Quote
Old 04-08-2011, 11:55 PM   #32
Re: rough idel
Interesting concept. Good thing I don't believe everything I read.
Old 04-09-2011, 12:58 AM   #33
Clearing things up. A CAI is just what it stands for. Cold air intake. Colder air will contain more oxygen than hot air. More oxygen means better combustion. May not lead to more power but it will allow the engine to be more efficient. The computer system will compensate for the added oxygen so there may be minimal fuel economy increases. Vehicles with Intake systems that are fairly restrictive will benefit more from a CAI. Unrestricted colder air always a plus. So they are not worthless but not a necessity. The computer system will always control air/fuel ratios. If your air filter is sitting under the hood and doesn't have a barrier around it or is not in the fender well away from heat, your doing nothing but sucking in more hot air.
Alscobra is offline   Reply With Quote
Old 04-09-2011, 05:17 AM   #34
ksrumbel's Avatar
Do you think colder air is actually making it way into the combustion chamber? Is the degree change actually different? Maybe when you first run the car it might be true but after driving awhile pull over and feel the intake tube. It is hot as hell. I'm just thinking out loud. I wonder of anyone actually tested to see if the air is actually cooler. Maybe If they get a display from the air temp sensor? Thoughts?
Old 04-09-2011, 05:20 AM   #35
Under 20 mph the air underhood is much warmer then the outside air. Above 20mph the difference in temp is negligeable
Rough idle upton7 1996-2004 Mustang GT 2 12-14-2009 07:34 AM
Rough Idling greenmustang27 Pre-2005 V6 Mustang 2 05-14-2009 08:29 AM
ROUGH IDLE joseandmarilyn 1979-1995 Mustang GT 8 09-27-2007 11:39 PM
Idel @ 2800 ? idrivehotrods Pre-2005 V6 Mustang 0 02-27-2007 07:34 PM
Rough Idle and Rough Start Cajun JungleBoy Pre-2005 V6 Mustang 3 04-23-2006 10:33 PM
02:06 AM
