Auto windows acting up!!! - Mustang Evolution
Old 04-09-2011, 11:51 PM   #1
04DSGM1's Avatar
K so my auto windows at times will not go down on the driverside. Sometimes playing with the switch (hitting up and down) it will then work. It has never happen while the window was down, only when it was up. Any ideas on what is wrong and how to fix it.
2004 Dark Shadow Gray Metallic Mach 1
K&N Air Intake
04DSGM1 is offline   Reply With Quote
Old 04-09-2011, 11:52 PM   #2
04DSGM1's Avatar
Re: Auto windows acting up!!!
EDIT: The passager side works fine.
K&N Air Intake
Old 04-09-2011, 11:53 PM   #3
This happened to my cousin's cougar...it was the switch...soomething came loose and you had to play with the switch and look like a complete idiot for it to work but the motor was fine and you could control it from the dricer's side better
2008Shelby is offline   Reply With Quote
Old 04-10-2011, 12:17 AM   #4
Happened in my '02 GT as well, but it got stuck down. I hit it where the motor is and it worked fine after that. I was told that eventually the motor will have to be replaced, but it hasn't given me any trouble since.
93CobraGuy is offline   Reply With Quote
Old 04-10-2011, 12:21 AM   #5
04DSGM1's Avatar
Thanks ya'll. I will look into the switch.
K&N Air Intake
Old 04-10-2011, 12:35 AM   #6
Loc: Austin,TX
Might wanna try taking the switch out and dusting it with a detailing brush.Sometimes the contact points collect some grime and cause it to stop working,if not...pick up a new switch like stated above.Start with the small stuff.
Old 04-10-2011, 12:47 AM   #7
Also you could spray some electrical cleaner on it as well.
Old 04-10-2011, 11:24 AM   #8
wereKEV's Avatar
could be dirty contacts.
wereKEV is offline   Reply With Quote
auto power windows tylbrune 2005-2010 Mustang GT 21 04-20-2014 05:48 PM
Help Me. Dome Light Acting Up brentmustanggt 1996-2004 Mustang GT 17 08-31-2010 10:57 PM
Acting weird in neutral 4.10GT 1996-2004 Mustang GT 0 09-07-2008 08:51 PM
Stereo acting up/loud pop I_luv_HP&trq Mustang Audio & Video 5 02-09-2006 10:04 PM
My PC is acting dumb Seph The Bar 6 02-05-2006 08:24 AM
08:51 AM
