1996 Mustang engine question - Mustang Evolution
Old 04-11-2011, 10:00 PM   #1
Region: Nebraska
I've an 96 mustang v6 with a 5 speed that I bought for $400 with a bad tranny I put a new tranny in it but now I want more power and have alot of ideas just don't know if some will work or not so here goes
Big block 460 but don't know if it will fit had one in my old mustang but it was a tight fit (89 fox body)
Big block 400 again don't know if it will fit
Small block 351 stroked to 408 I think it will fit but not sure
Small block 302 stroked to 347 I know it will fit but like my grandfather always told me bigger is better
So if anyone had, has, or even seen a big block in the 94 thur 98 body style mustang let me know thanks
Chmiller85 is offline   Reply With Quote
Old 04-12-2011, 10:59 AM   #2
Titus Wadicus
svtlx's Avatar
Re: 1996 Mustang engine question
all your combos will fit up to "03 mustang as long as u use a v6 k-member (which u already have) or an aftermarket k-member for 94-95gt
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-12-2011, 11:30 AM   #3
Snapple750's Avatar
Why not '04?
2 Legit 2 Quit
Snapple750 is offline   Reply With Quote
Old 04-12-2011, 12:15 PM   #4
you can build the 3.8L but the end result probably wont make you happy vs the money invested.
If you want to go cheap then you can build a carb'ed motor, trans, and 8.8 rear end with upgraded fuel lines/pump setup and your good to go.
Old 04-12-2011, 02:03 PM   #5
Titus Wadicus
svtlx's Avatar
Originally Posted by Snapple750 View Post
Why not '04?
yea... 04 too, my bad i was in a rush earlier.
Old 04-12-2011, 02:06 PM   #6
Titus Wadicus
svtlx's Avatar
y would he have to upgrade fuel lines if he stays below '99 1/2? (99 1/2 v6 went to returneless lines) he would just have to a return.
Old 04-12-2011, 02:39 PM   #7
well I guess I was just talking about the fuel type, carbed, etc who knows the final idea that will go into the car.
Old 04-12-2011, 02:49 PM   #8
Titus Wadicus
svtlx's Avatar
o...ok. well even with carbed cars an in-line electric or mechanical block mount pump will pull fuel through an existing in-tank... the chevy guys taught me that trick with efi to carb camaros
1996 mustang
1996 V6 to V8 engine swap. deere291 Pre-2005 V6 Mustang 2 04-09-2010 10:21 AM
1996 interior question fre2rome General Mustang Discussion 3 10-10-2009 11:32 PM
1996 mustang? mustangmadnes09 General Car Discussion 6 09-04-2008 11:31 AM
1996 Mustang GT Buzz 1996-2004 Mustang GT 1 04-22-2006 12:48 PM
1996 GT Stang engine swap with.... cagedthought 1996-2004 Mustang GT 12 03-28-2005 08:27 AM
05:21 AM
