460 MACH AMP - Mustang Evolution
Old 04-12-2011, 11:51 AM   #1
fpierce's Avatar
460 MACH AMP
Hi All
I'm new here, I have a question about the 460 MACH amps in the 2002 GT. My car didn't come with any and after some research I belive I have one of the two and I believe its the right one to into the car (p/n f7zf-18c808-aa) should it have worked even on just one side when I plugged it in, or do I need both in at the same time for it to work at all? I'm trying to make sure I have the right one. Or is there a way just to bypass the amps all togher? Any other suggestion are welcome. Thanks
fpierce is offline   Reply With Quote
Old 04-12-2011, 12:13 PM   #2
Re: 460 MACH AMP
I believe you need all the amps, there should be more than a couple. I think there was one under the head unit, two in the back under the trunk, and maybe one on each door behind the kick panel~
Old 04-12-2011, 12:42 PM   #3
fpierce's Avatar
Re: 460 MACH AMP
Oh really I didn't know about the others. I'll have to check this weekend. Is there anyway to by pass them because just my tweeters are working now and it is terrible!!
Thanks again
Old 04-12-2011, 01:18 PM   #4
Re: 460 MACH AMP
yea im sure you can bypass them but they require an amp source to sound right so you may just need to replace it all
Old 04-12-2011, 04:31 PM   #5
Snapple750's Avatar
I've disconnected one of my amps, it works with just one amp, although I don't if it's the same
2 Legit 2 Quit
Snapple750 is offline   Reply With Quote
Old 04-12-2011, 04:31 PM   #6
Snapple750's Avatar
Thanks again
When I disconnect an amp in the trunk the bass goes away, this is because those amps(in the trunk) are built to just power the woofer. I am almost sure that the one under the head unit is for the tweets. I think you might have a bum amp
2 Legit 2 Quit
Old 04-12-2011, 05:04 PM   #7
fpierce's Avatar
Yes my tweets are working just the base isn't. I know the base speakers work I hooked them up to my sons iPod just to test them and thy worked fine. Maybe ill just try to rewire them. Anyone did anything like that?
Old 04-14-2011, 10:11 AM   #8
Snapple750's Avatar
Well, unless you snip the harness it's pretty set in stone about the wiring, you could try another wiring setup but should work normally
2 Legit 2 Quit
Old 04-15-2011, 07:48 AM   #9
Snapple750's Avatar
Here's a diagram if you snipped it
2 Legit 2 Quit
Mach 460 Amp question joestang406 1996-2004 Mustang GT 9 09-25-2010 07:05 PM
I am looking for Mach 460 front speakers and rear amp a3705872 Mustang Audio & Video 9 11-07-2009 05:10 PM
WTB: Mach 460 amp greenpony02 Mustang Parts for Sale and Wanted 2 07-06-2007 07:46 AM
mach 460 Warfire80 Mustang Audio & Video 15 03-03-2004 09:34 AM
Mach 460 starboarder2004 Mustang Audio & Video 19 01-20-2004 09:23 PM
10:49 PM
