2V Supercharging - Mustang Evolution
Old 04-14-2011, 01:05 PM   #1
Lastoria24's Avatar
Send a message via Skype™ to Lastoria24
2V Supercharging
I'm leaning towards the Vortech (V2?) Supercharger, once I get the money/time to do it, probably won't be until fall or something...
The whole kit just really appeals to me. From what I can tell, i literally won't need to buy anything else other than this kit. My Mustang is total stock trim, outside of exhaust and a shifter.
Am I mistaken by this? Will i need to have it dyno tuned? Will the driveability change much? What appeals to me is having a car that can take a beating, be a little quicker than stock, sound good and still be carefree to own.
Example, i had a 2000 SS 6spd, that i did heads/cam/rear end/clutch, headers, etc... It was fast, high 11's which was substantial over stock. The thing that killed me was how i didn't even enjoy driving the car anymore. I had a "hotcam" in it, an it thumped hard on idle, went through all sorts of nightmares trying to get the MIL off, had it dyno tuned, mainly to run better, etc... Did tons of suspension work too, which also killed it for me. The Eibach kit made the car look wicked, but it rode so hard. I even put KYB 8-ways on it and it didnt make a difference. Long story long, i hated just about everything I did, even though it looked sick and was pretty fast.
All i care about is possibly picking up some hp/tq, passing emmisions, no MIL, and run/drive near stock. Maybe I'm dreaming, but I hope this is something I could do...
Wow, if any of you read this whole post, my apologies. I tend to rant when i have something im trying to get off my chest...
Lastoria24 is offline   Reply With Quote
Old 04-14-2011, 01:15 PM   #2
Re: 2V Supercharging
you will end up around 380-400rwhp depending at about 10psi. Reliability wise you MUST have the vehicle custom tuned which can run you a good bit depending, you do NOT want to run the tune that they send you.
You will end up needing a new clutch etc etc as parts wear more with more hp. Drivability should not suffer that much as its boost so you only use it when you want it~
If you are really looking for a good solid platform thats easy and cheap to make great power from with a built motor and many other great extras then consider selling your car and saving that 5-6k you would need to put a supercharger on it and purchase an 03/04 cobra that will have about the same hp/tq stock as you would with a GT and a supercharger.
Exhaust/Intake/different supercharger pulley size/tune you are looking at 450-470rwhp/tq for a very small investment and you can go MUCH further instead of being maxed out at 10psi/400rwhp... you will have room to grow up to about 600rwhp
Old 04-14-2011, 05:38 PM   #3
Stang.racr's Avatar
make sure you got bigger fuel pump and injectors, and deff have it dyno and tuned at a shop, u will get more power out of them fine tunning it
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 06-04-2011, 01:35 AM   #4
98gtdriver's Avatar
I am thinking about doing this too! What would I need to run 10 psi?
-Eric
98gtdriver is offline   Reply With Quote
Old 06-04-2011, 08:31 AM   #5
iwannagofast's Avatar
i have a vortech im my 98 gt and i love it, drivablity didnt change. Like the guys before me said, get the custom tune, bigger injectors (i have 42LB), and a bigger fuel pump (I have a 255lhp).
iwannagofast is offline   Reply With Quote
Old 06-04-2011, 10:16 AM   #6
98gtdriver's Avatar
Oh sweet how much psi you running?
-Eric
Old 06-05-2011, 05:13 AM   #7
onesickstang01's Avatar
I run the v2 in my 03 gt and love it. Dyno tune is a must. I have a 2.95 pulley as well as a anderson power pipe and aftercooler kit. Im running 13-14 psi. I have a 255 pump(new walbro for returnless system) and my fuel pressure dropped off at 3500rpm. I made 409 wheel with the fuel pressure cutting off. My tuner said once i install my boostapump ill make 460 wheel on a moderate safe tune and it will still drive like stock until i put it to the floor.
onesickstang01 is offline   Reply With Quote
Old 06-05-2011, 09:08 AM   #8
not sure on the size of the pulley, but according to the dyno sheet at redline its putting in 8.5lbs of boost.
Old 06-05-2011, 09:00 PM   #9
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
My .02......from my supercharged 2V and 4V experience.
If you want to do it RIGHT, you will need AT LEAST an SVT focus fuel pump (usually people go with a Ford GT pump now because of availability and capability), 42 lb. injectors, a BA-2400 MAF, and a dyno tune.
You *could* get away with a boost a pump, stock MAF, injectors (or maybe even an FMU), and the canned tune......but I would advise ANYBODY against that.
What I stated above will definitely cost a little more....but it will be more safe, it will perform better, and it is simply better.
I'm partial to Vortech, I've owned 4 of them I think....but remember that they don't come with an intercooler standard like ProCharger kits do. Not necessarily required depending on climate, vehicle purpose, etc.....but definitely nice to have given the option.
Make sure you have supporting bolt ons if you bolt on a supercharger. You *can* put one on a stock car.....but it doesn't make much sense to spend all that time and $$$$ forcing air in if you can't get it out (meaning you need a good flowing exhaust).
Done right it should be a VERY comfortable, fun to drive, dependable vehicle. I've owned supercharged mustangs and cammed LS vehicles....if you're looking for something that you don't have to "put up with" quite as much, it sounds like you're on the right path.
-Will
Waffles
Knight F Mohawk is offline   Reply With Quote
Old 06-05-2011, 09:21 PM   #10
98gtdriver's Avatar
Ok it sounds likea lot. The maf is just the thingconnect to my cai correct? I don't know what injectors are and don't some kits come with. A new fuel pump?
-Eric
Old 06-07-2011, 03:33 AM   #11
not to sound like a dick but if you dont know where ur MAF is and what injectors are then this project maybe too much for you to handle
Old 06-07-2011, 06:31 AM   #12
MonteCitan's Avatar
You didn't mention that it would cost twice as much to replace a cobra 4V when the engine lets loose, and the clutch is very heavy for daily driving
I looked at cobras/2011 GTs and ended up getting the 06 GT over both..
My 01 GT w/procharger @10PSI put down 382 WHP and 366 tq on 91 octane tune. It is not all that loud and people don't expect it like they do with the cobra
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 06-07-2011, 08:16 AM   #13
the clutch doesnt have to be so stiff, no idea why its that way really. An after marekt which holds more and is better is as light as an OEM GT's which has always been odd to me... but someone with an 03 cobra with 400rwhp~ has nearly 300k on his stock clutch
Old 06-07-2011, 08:21 AM   #14
Send a message via Skype™ to Texastboneking
+1. Supercharging is not for newbiees.
Texastboneking is offline   Reply With Quote
Old 06-07-2011, 08:41 AM   #15
well there are always good shops that can handle all that stuff, you just have to decide that if the car were to blow up tomorrow you could handle it, not that it would be fun but its not going to destroy your life or what not as thats always a possibility on any car, more so on supercharged etc ones pushing far more hp.
Old 06-07-2011, 11:36 AM   #16
98gtdriver's Avatar
I was just making sure!!! But whatever man!
-Eric
Old 06-07-2011, 08:59 PM   #17
If you are telling the truth here and not joking, you need to do a LOT more research and/or pay somebody to do this for you.
-Will
Waffles
Old 06-07-2011, 11:04 PM   #18
98gtdriver's Avatar
Yes obviously I would. I can't a supercharger for 2500. Its a bolt yeahh the fmu is the most complex thing but it will done. Thanks for trying to help me though. The only reason asked were the maf was because I don't understand why I would need a bigger one if its just a sensor.?
-Eric
Old 06-07-2011, 11:12 PM   #19
Factory maf is too small and will restrict the airflow to the supercharger.
Old 06-08-2011, 01:22 AM   #20
98gtdriver's Avatar
Oh ok thanks!!
-Eric
Old 06-08-2011, 01:38 AM   #21
Pete07GT's Avatar
Send a message via ICQ to Pete07GT Send a message via AIM to Pete07GT Send a message via Yahoo to Pete07GT
Oh ok thanks!!
You live in WA. and you want to drive a SC Stang? Amazing...
When you're going to war, you better have three things if you expect to win: 1. Willpower (One's need to put the petal to the metal); 2. Staying Power (300+ BHP); and 3. Firepower (The wheels of your mustang exploding on the highway like a slug from a .45).
Pete07GT is offline   Reply With Quote
Old 06-08-2011, 02:47 AM   #22
98gtdriver's Avatar
Why do you say that?
-Eric
Old 06-09-2011, 05:26 PM   #23
An upgraded fuel pump and larger injectors are FAR superior to an FMU.
The stock MAF sensor is only capable of reading so much....I.E. this limits the amount of horsepower it can support
-Will
Waffles
Old 06-10-2011, 12:13 AM   #24
98gtdriver's Avatar
Oh ok thank you for making it clear!!
-Eric
SUPERCHARGING usmc_berkeley 2011-2014 Mustang GT 5 12-19-2009 10:21 AM
supercharging this b!tch bobbyoooo 1996-2004 Mustang GT 2 04-09-2009 09:15 AM
mods for supercharging btant Pre-2005 V6 Mustang 9 09-12-2008 07:19 AM
Milage on 2007 v6,Supercharging Next! ggbiw Pre-2005 V6 Mustang 6 09-24-2007 09:37 PM
Thinking of supercharging - Ken The Bar 20 02-01-2006 09:57 PM
07:57 PM
