Cobra head swap - Mustang Evolution
Old 04-15-2011, 08:05 PM   #1
1ijack's Avatar
Send a message via Yahoo to 1ijack
Cobra head swap
I was wondering if you could replace the stock 2v heads from a 1999 gt and upgrade to a set of 99 cobra heads. And how much work would it be to have the ecu flashed for such an upgrade.
If this can be done I have found me next project. Would you still be able to use the track heat intake with these heads please I am looking for hp.
The Mustang Mafia
"Join the family, if you dare"
www.themustangmafia.com
1ijack is offline   Reply With Quote
Old 04-15-2011, 08:23 PM   #2
I would spring for the complete engine swap. Still gonna have that 2v bottom end in it.
Alscobra is offline   Reply With Quote
Old 04-16-2011, 07:05 AM   #3
stampde's Avatar
Re: Cobra head swap
the 4 valve has a diff block than the 2 valve , dont think it can be done ?
just pick up a 4 valve engine , if you look for just the engine they want a ton of cash for them , try and track down a used mid 90's Lincoln Mark 8 , my Dad bought one for $1800 with only 88,000 miles on it and it runs Strong !!!
2011 GT Auto
Old 04-16-2011, 07:36 AM   #4
Beav's Avatar
Re: Cobra head swap
What Stampede said..
07 Roush 427R, Brembo 14" rotor and four piston calipers
05 GT Mustang, FRPP, FR X pipe, Hurst short throw,
American Racing Torque Thrust 10X20 wheels,
Granettelli tower brace, custom painted flat black grafix, Yellow Optima
Beav is offline   Reply With Quote
Old 04-16-2011, 10:16 AM   #5
wereKEV's Avatar
Re: Cobra head swap
Thats the way to di it.
wereKEV is offline   Reply With Quote
Old 04-16-2011, 11:41 AM   #6
04machazblue's Avatar
I wouldn use the heads a off a cobra then the mark 8 heads and u can Change the intake
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 04-16-2011, 05:34 PM   #7
Beav's Avatar
Re: Cobra head swap
FORD DOHC 4.6 Motor--56K Complete Running Engine | eBay
Old 05-02-2011, 04:52 AM   #8
32vNomad's Avatar
The heads can be used on the 2 valve block. But you need the intake, fuel, exhaust, etc. Besides the stock bottom end is the same internals that an auto mach 1 has. Only difference is that the mach 4v block is aluminum. The gt bottom end is good up to 400+ hp more than enough for a head swap.
32vNomad is offline   Reply With Quote
Old 05-02-2011, 06:41 AM   #9
Re: Cobra head swap
The reason the 4v head swap is not cost effective is that you need lots of parts to make it work. Aside from the heads/intake and tune you would also need crank, pistons, timing chains, front cover, alternator, inlet tube, 24lb injector and matching MAF, harness or modifiy stock harness to work, flywheel (cobras are 8 bolt 96-98, 01-03 GT's are 6 bolt). Reason you need crank is that the Cobra motor makes it's peak power above 6K RPM and you need to be able to rev to 7K regularly to take advantage of the power band. Pistons you need becuase without them you will only have about 8.5:1 and 4v motors have 9.5:1+.
If you simply bolted on the heads and did the swap minus the internal parts I would be surprised if you saw more than maybe 5-10RWHP peak gain because the peak would never be reach with the stock 2v rev limiter and you would lose a good amount of torque down low. If you ever get a chance compare a stock GT to stock Cobra dyno chart and you'll see the GT makes more torque down low and it's due to small port size for better velocity.
Old 05-02-2011, 01:55 PM   #10
32vNomad's Avatar
Agree about compression, if boosted then that's idea. But disagree on crank, mach auto crank is the same. now if he is planning a high horsepower car I would say upgrade but for something mild on the street, on a budget then run what you brung. Plenty of 2v or there running stock cranks with hp. As said previous post, find a mark motor, use your heads get some cams, and a tune.
Old 05-04-2011, 07:45 PM   #11
Send a message via Skype™ to Texastboneking
Re: Cobra head swap
um. just incase anyone wanted to do the swap. i have a set of 97 cobra 4v heads for sell. new with new valves. no cams.
Texastboneking is offline   Reply With Quote
Old 05-04-2011, 09:46 PM   #12
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
Re: Cobra head swap
Disregard every post in the thread but this one. This is spot on.
It can be done....it's just not worth it.
-Will
Waffles
Knight F Mohawk is offline   Reply With Quote
2v to 3v head swap 05gtstang 2005-2010 Mustang GT 1 01-13-2011 07:29 AM
98 gt cobra head swap?? Supersnake4.6 1996-2004 Mustang GT 7 01-12-2011 09:19 PM
head swap juced302 1979-1995 Mustang GT 0 10-28-2009 08:24 PM
95 - 99 head and intake swap kack85 Pre-2005 V6 Mustang 2 04-26-2009 09:21 AM
Intake and head swap!?!? JERIC Pre-2005 V6 Mustang 6 09-13-2004 06:48 PM
01:39 AM
