Question! - Mustang Evolution
Old 04-17-2011, 06:56 PM   #1
Region: New Mexico
Question!
Can someone help me out please? Today I was on my way to pick up my fiance from work and I had the AC on. I came to a stop and my rpm dropped from 900 or so and just died. And now my rpms drop below 500 or every time I stop. Can some one help?
9NIGHTMARE9 is offline   Reply With Quote
Old 04-18-2011, 07:55 AM   #2
Titus Wadicus
svtlx's Avatar
Re: Question!
prolly your i.a.c. idle air control motor...it's on the throttle body
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-18-2011, 09:28 AM   #3
Region: New Mexico
Thank you
04:01 AM
