Tob huge issue help - Mustang Evolution
Old 04-18-2011, 01:11 PM   #1
Tob huge issue help
My mustang has went through three throw out bearings I'n the last six months basically it always stays engaged i know for a fact I'm correctly installing the bearing I've done clutch kits a million times but i can't figure out why it's riding like it is two days after install it's chirping and it drives me crazy is there a spring or return or anything that was on it that was missing when i got the car this is getting expensive and rediculous please help
Stangforlife is offline   Reply With Quote
Old 04-18-2011, 01:15 PM   #2
Re: Tob huge issue help
It sounds to me like you have too much pre-load or you keep finding the garbage TOB's in each batch...which if thats the case, it's time to play the lotto.
What brand TOB are you replacing the bad ones with?
Do you have an adjustable cable/firewall adjuster/etc? Or is this just a stock cable stock plastic quadrant in the car?
Old 04-18-2011, 02:54 PM   #3
i went through 4 in like a year.. clutch adjustment seemed to really help the life though on the last go around. What is your cable/quadrant setup?
Old 04-18-2011, 04:43 PM   #4
It's a stock setup but when i adjust it it will ether click right back to where it was or will be looser then jeff gordons car at daytona speedway
Old 04-18-2011, 05:22 PM   #5
Order yourself and adjustable set up. There are kits that include firewall adjuster,quadrant, and cable from steeda for $100. Should take care of things.
Alscobra is offline   Reply With Quote
Old 04-18-2011, 08:24 PM   #6
Oh ok Im guessing this is a pretty common issue
Old 04-18-2011, 09:35 PM   #7
You'll have to either adjust the cable placement or put a pre-load on the tob. Either would work.
Old 04-18-2011, 10:09 PM   #8
I'm just going to try and replace the whole setup the car had a centerforce clutch on it when i got it might have bent something also it has a none pi engine that wouldn't cause any issue that i know of though because that i know of the block is almost identical of coarse i had to get a new flexplate because this engine was a six bolt the pi engines have a 8 but the clutch kits are the same for the two
Old 04-19-2011, 12:53 AM   #9
I would stick with a ford racing TOB
Dj77 is offline   Reply With Quote
Old 04-19-2011, 04:25 AM   #10
gixxer007's Avatar
I would agree with above put a good cable and adjuster on it and hopefully that will help out.
Good luck and keep us posted on what may take care of this issue in the end.
gixxer007 is offline   Reply With Quote
Old 04-19-2011, 09:10 AM   #11
the retainer sleeve may have grooves in it, replace with steel instead of an alum one
Old 04-19-2011, 10:02 AM   #12
wereKEV's Avatar
I just got rid of my 98 it's tob was making noise for along time it was a good excuse for me to get a newer car. and ya the noise drove me nuts , I gave up and got an auto trans on this one.
wereKEV is offline   Reply With Quote
Old 04-19-2011, 11:14 AM   #13
I couldn't go back to a auto i could never keep one for longer then a month two races and something wa broke of coarse a twin turbo setup with spray on a v6 auto trans probly didn't help matters none but never had a issue with the car othe then the tob gotta expect something messed up when i rebuilt the entire car after it burnt up I'n a engine fire
Old 04-19-2011, 11:17 AM   #14
wereKEV's Avatar
Mine is a daily driver in california the traffic gets so bad that I got the auto because i'm too lazy to shift anymore.
Old 04-19-2011, 06:58 PM   #15
How do the mustangs there perform with all the enviornment controls on them? Where i live we dont even have emission laws cherrybombs will pass inspection and you only get an inspection when you first buy the car no yearly inspections
Old 04-20-2011, 12:33 PM   #16
wereKEV's Avatar
It all depends on how much money you want to spend mine has a supercharger on it and it performs pretty well 0to 60 in about 5 seconds .
Old 04-20-2011, 06:40 PM   #17
That's not bad what kind of emission laws do they have? I was looking into moving there
Old 04-20-2011, 07:47 PM   #18
wereKEV's Avatar
For one thing you have to have cats on your car, as for the ppm and technical info I'm noy sure.
Old 04-21-2011, 09:31 AM   #19
Oh i probly would just be better off buying a new car no cats no smog pump fuels turned up etc
Old 04-21-2011, 09:51 AM   #20
wereKEV's Avatar
If you want a true race car to drive on the street that is legal don't move here.
Old 04-21-2011, 09:54 AM   #21
Louisiana. We've got tube chassis and parachutes street legal.
Old 04-21-2011, 10:06 AM   #22
+1, not to mention the inability to get any kind of good gas out there.
Old 04-21-2011, 11:52 AM   #23
We have ethonal here I'n our gas and it breaks down I'n less then a month
I have a huge delima and need your help sonic04edge The Bar 29 04-21-2008 03:10 PM
I have a HUGE dilemma Zim The Bar 31 07-27-2005 04:46 PM
HUGE wave Brent The Bar 7 09-24-2004 10:45 PM
05:51 AM
