Bottoming out. Help please! - Mustang Evolution
Old 04-21-2011, 07:58 PM   #1
Romeofalls's Avatar
My car bottoms out (scraps against the ground) when I go over some speed bumps. I live in a gated community and normal hit the one right at the gate, and Im scared Im gonna rip it to shreads if this keeps up, what should I do?
Romeofalls is offline   Reply With Quote
Old 04-21-2011, 08:01 PM   #2
ksrumbel's Avatar
What is scraping? Body or undercarriage? Can you drive through grass to avoid the speed bumps?
ksrumbel is offline   Reply With Quote
Old 04-21-2011, 08:03 PM   #3
Romeofalls's Avatar
Re: Bottoming out. Help please!
No I cant, the police would take me down, plus theres a wooden fence. Also Im not sure, I think its the undercarriage, eather way I want to get it fixed.
Old 04-21-2011, 08:08 PM   #4
ksrumbel's Avatar
I'm assuming the car is lowered??
Old 04-21-2011, 08:10 PM   #5
Romeofalls's Avatar
Once again wouldnt know. Sorry, Im a fail. >.< But I was suprised with it. So I dont know what was done with it when my parents bought it.
Old 04-21-2011, 08:16 PM   #6
ksrumbel's Avatar
It would have to be lowered if it is bottoming out on speed bumps. If you want it to stop I would suggest finding out how much the car was lowered and start looking for a different set if springs to give it a little more clearance. It kinda sucks that you can't get around the speed bumps. I don't know if anyone else will have any other tricks. I avoid speed bumps at all costs being lowered 2". I have never gone over a speed bump since being lowered
Old 04-21-2011, 08:19 PM   #7
Romeofalls's Avatar
Most I can. But those I cant, and the weird thing is. The one at the gate is the only one that does it.
Old 04-21-2011, 08:21 PM   #8
ksrumbel's Avatar
Is it possible to not hit the speed bump straight on?? If you take it at an angle you will have a better chance if not scraping. Try that and see how it goes
Old 04-21-2011, 08:31 PM   #9
blackonblack's Avatar
go over it at an angle..
2004 3.9L v6
Black on black on black
MAC Cold Air Intake, 4.10 gears + T-Lok, SCT Tuner, dual H piped flowmaster super 40's
blackonblack is offline   Reply With Quote
Old 04-21-2011, 09:03 PM   #10
Brett Greene's Avatar
Go like very very slow. And go over it sideways if at all possible. I have the same problem. My headers hit.
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 04-21-2011, 10:57 PM   #11
Jamesgt08's Avatar
Do u have a pic of the car to see how low it is?
Jamesgt08 is offline   Reply With Quote
Old 04-22-2011, 12:47 AM   #12
Slow03GT's Avatar
I had a similar problem with my GT in my old condo complex. I'm running H&R Super Sport Springs and I took each speed bump as slow as possible and at an angle every time. I didn't change my springs because I knew we would be buying a house in the future so I just dealt with it until we moved.
Unless the speed bumps in your complex are abnormally huge your car was probably lowered by the previous owner at some point. Which means the only way to fix your problem is to get taller springs unless you plan on moving as I did.
03 Dark Shadow Grey GT: 03 Cobra Brake Upgrade, H&R Super Sport Springs, Magnaflow Magnapack Catback, Anthracite FR500s with Continental ExtremeContact DW tires all around, Steeda Tri-ax, Maximum Motorsports Full Length Subframe Connectors, plus much more...
Slow03GT is offline   Reply With Quote
Old 04-22-2011, 07:17 AM   #13
raise it up, if its stock ride height you should have NO trouble clearing things.
Old 04-22-2011, 11:12 AM   #14
nickysixx's Avatar
try approaching it at an angle. thats what I have to do with some speed bumps
nickysixx is offline   Reply With Quote
Old 04-22-2011, 01:13 PM   #15
Yah it's more than likely lowered...a considerable amount too.
As said, either buy some springs that lower the car less, maybe some Ford Racing C Springs or Eibach Pro Kit Springs.
If you can tell how much the car is hitting by you might be able to throw some isolators in the tops and bottoms of the springs and clear the bumps. That way you'd still get the nice drop and not scrape every time.
Old 04-22-2011, 01:29 PM   #16
Snstr99svt's Avatar
I have H&R springs on my car and it's about a 2 inch drop and all I do is go over speed bumps sideways and really slow and I have no problems.
Snstr99svt is offline   Reply With Quote
« Miles | rears going »
09:01 PM
