1998 gt engine swap - Mustang Evolution
Old 04-24-2011, 05:59 PM   #1
1998 gt engine swap
1998 gt...stock cept for exhaust and cold air.
im currently in the airforce and they have shops for $2 a hour and free tools so im thinking of working on the baby a little while here.
long story short....the 4.6 is starting to crap out and not be enough for me any more....
I'm looking to go 302 carb'd(not fi)....this one in particular.....302 350 FORD Crate Engine, Ford Motorsport for Mustang,Fairlane,Comet,
i want a carb'd 5.0...any better engine than the one i've showed.....i want a 5.0 with atleast 300-350hp....I'd like a cammed 5.0(love how they sound)
what all do i need to put this in my car? im not new to working on cars im fairly educated on them....i just need a list of what needs to be bought and done.
also
is there any crate 4.6 drop ins carb'd with the power im looking for?
thank you
Eddie
eddie1 is offline   Reply With Quote
Old 04-24-2011, 06:03 PM   #2
Las0mbra's Avatar
I would go 347... Way easier to make that power
Edit: actually, just checked the link. Ignore my comment, that looks pretty good.
Old 04-24-2011, 06:45 PM   #3
Titus Wadicus
svtlx's Avatar
Re: 1998 gt engine swap
also
thank you
Eddie
your gonna need a 94-95gt k member or a 3.8 v6 k member... im currently doing the same thing but im goin efi.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-27-2011, 05:28 AM   #4
Nate98stang's Avatar
I've got a 98 gt and was thinking a 347 anyone have s ball park figure as to what the whole swap would cost?
2002 5 speed Comp Orange Mustang GT. K&N CAI,JBA headers,BBK xpipe,SLP mufflers to turn downs,Exedy stage 2 clutch,MGW short throw,drilled and and slotted roters,front:17x9 black 10th anniversary cobras Rear:17x10.5 black 10th anniversary cobras,Roush stage 3 body kit,smoked tails and side markers.
Nate98stang is offline   Reply With Quote
Old 04-27-2011, 08:05 AM   #5
Titus Wadicus
svtlx's Avatar
that's a loaded question dude. anywhere from 3500-10k, depending on how u source the parts and how much of the work you do yourself.
750-1200 on a stroker kit depending on where u buy it.
are you gonna assemble the motor and clearance the block yourself? (huge savings)
it can get up there if you're payn ppl and shops to do the work.
Old 04-27-2011, 09:10 AM   #6
Was just curious I'm not too mechanically inclined so I'd b paying some one or having friends help
Old 04-27-2011, 10:30 AM   #7
Titus Wadicus
svtlx's Avatar
ewww , i c. you're a bold man tryn to do a 347 swap. thatsa a ton of work u r signing yourself up for. it's not really a novice job.
Old 04-27-2011, 01:09 PM   #8
Well it's not something I'm going to taking just yet I'm only 18 with not such a great job few years down the road a 347 might come
V6-V8 Engine Swap KhaoticMustang 1996-2004 Mustang GT 9 11-24-2016 12:13 AM
engine swap midnightrider_s Pre-2005 V6 Mustang 1 10-22-2009 09:49 AM
engine swap 1989 to 1992 4 cyl engine dannyc1992 General Mustang Discussion 0 02-08-2008 01:59 PM
Engine Swap/ Engine Shakes too_cool_mitch Pre-2005 V6 Mustang 2 02-28-2006 02:01 PM
engine swap evilweirdo42 Pre-2005 V6 Mustang 26 11-23-2004 07:21 PM
05:44 PM
