dash lights out after installing aftermarket radio - Mustang Evolution
Old 08-09-2007, 08:45 PM   #1
I recenlty change my radio ( 2000 gt mach 460 audio ) I got the harness for it. After evrything was done my dash lights don't work Headlights and side markers work fine. I took the orange wire from the harness and put power to it and the dash lights light up permanently, then don't work with the knob. I can figure out what I am missing. There is no dimmer wire on my radio. Can any one help with this.
vblic is offline   Reply With Quote
Old 08-09-2007, 08:49 PM   #2
Re: dash lights out after installing aftermarket radio
If all you did was get a plug and play harness then you have another different problem not associated with the stereo. If you did however cut wires and tap into the factory harness that way then you could have messed something up.
Old 08-09-2007, 09:18 PM   #3
OsirisGuy's Avatar
Don't use the orange wires. Most installers don't use the dimmer wire on any car install since they blow fuses anyway. I would first check to see if a fuse was blown by either pulling it out, better yet check it with a test probe or see if any other parts of the car use that same fuse and check to see if they are working.
Without looking at it or knowing what you did/hooked up it's the best I can say. I never looked at 99+ wiring and install but if the problem persists I could try and look through the install and see where you might have gone wrong.
Then again perhaps some one else on here has ran into the problem/done this install and will know the answer right away.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 08-10-2007, 06:46 PM   #4
i used a harness. Didn't cut any factory wires. And didn't use the orange wires. I did many installs on mustangs 1987-1993. But I did everything by the book. I did check the fuse under the dash and under the hood. Everything checked out. I appreciate the help guys. The dash do work.
Best aftermarket radio for 2007 Mustang? OIF2007Mustang Mustang Audio & Video 2 06-01-2010 03:34 PM
Need Help Installing New Aftermarket Head Unit and Subs with Amp! 99supercharged Mustang Audio & Video 8 04-15-2010 11:57 PM
dash lights blow out eddie1 1996-2004 Mustang GT 9 06-09-2009 02:34 AM
Installing an aftermarket deck? mvp828 Pre-2005 V6 Mustang 5 06-16-2008 02:14 PM
Mustang 99 up 6cd in dash changer Radio $200 Acha3 Mustang Parts for Sale and Wanted 6 08-26-2004 10:22 PM
12:33 AM
