Ford Racing Boss Modular 5.0L Engine Block (96-04 GT) - Mustang Evolution
Old 04-24-2011, 10:05 PM   #1
Something to consider for those that are thinking bout rebuilding their current engine...... thoughts ??
Ford Racing Boss Modular 5.0L Engine Block (96-04 GT) ..For $1,209.99
Modular 5.0L. Now you can install a Ford Racing Boss Modular 5.0L Engine Block in your very own SN95 Mustang on the cheap. This block reuses everything from your stock GT's 4.6L V8, all you need to supply is a new set of larger pistons and brand new 5.0 is complete.
Mustang Fitment: 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004
Ford Racing Boss Modular 5.0L Engine Block (96-04 GT) at AmericanMuscle.com - Free Shipping!
Dj77 is offline   Reply With Quote
Old 04-24-2011, 11:54 PM   #2
Re: Ford Racing Boss Modular 5.0L Engine Block (96-04 GT)
Looks like a good deal for someone needing a new engine.
http://i5.photobucket.com/albums/y200/mustangfan2003/MC.jpg?t=1196874772
Mustangfan2003 is offline   Reply With Quote
Old 04-25-2011, 06:37 AM   #3
Topless04GT's Avatar
whats the expected HP?
My girl... ehh, cars never leave you! stick to cars!
My name is Josh, Whats yours?
Topless04GT is offline   Reply With Quote
Old 04-25-2011, 07:16 AM   #4
Brett Greene's Avatar
Apparently you can fit these in the 94 95s to. Just have to move the mounts. I'm trying to sell my current mustang. And next summer I will probably build one of these. Keep it NA and see exactly how much power I can get outta the new 5.0
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 04-25-2011, 07:21 AM   #5
Las0mbra's Avatar
I'd just go turbo... You'd be much happier with the end result.
Old 04-25-2011, 07:30 AM   #6
Na I have a 650 rwhp stang now that's boosted. Sick of the constant repair/maintenance of boosted cars. I wanna beastly NA car
Old 04-25-2011, 08:19 AM   #7
yea the more you mod the more trouble you get into, why I decided an 03/04 cobra would work for me, only needs a couple mods to make good power and generally remains very reliable at 600hp.
Old 04-25-2011, 08:28 AM   #8
Very true my friend
Old 04-25-2011, 08:43 AM   #9
Titus Wadicus
svtlx's Avatar
i think i heard u mention this in another thread previously. how are you movin the motor mounts? a k-member swap just seems alot easier.
94-95gt and 94-04 v6 all have the same k-member
96-04gt k-member will bolt up into 94-95gt & v6... as well as fox bodies (for those wanting to do a mod motor swap into a fox)
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-25-2011, 10:35 AM   #10
To tell you the truth I never looked really into depth on it. Just was at my local mustang store and was chit chattin about it. He said it can be done just a little work. But yes I will probably end up doing a K member swap
Old 04-25-2011, 11:05 AM   #11
Titus Wadicus
svtlx's Avatar
i think ur shop buddy is think'n bout chevy swaps.....
Old 04-25-2011, 12:04 PM   #12
Lol defiantly not. They sell the motor for that year car and have already swapped a few out them selfs
Old 04-25-2011, 12:23 PM   #13
Not sure what you meant by "the new 5.0", but in case anyone else in thinking this....this boss 5.0 is NOT the new 5.0 that is going into the new mustangs. This is just a big bore 4.6L motor...completely different from the new 5.0 going into the mustang. In fact, it is a simple direct bolt in for the 03/04 cobras...timing cover and all just swaps right onto it.
Old 04-25-2011, 01:19 PM   #14
Correct, this is a 5.0 Modular engine block.
Would be pretty cool in a 4.6 but someone with 1994-1995 would not be worth the switch over.
Ford Racing 4.6 Modular PI Intake stangstar92 1996-2004 Mustang GT 7 02-26-2011 03:25 PM
07:29 AM
