twin turbo build. - Mustang Evolution
Old 04-27-2011, 10:19 PM   #1
twin turbo build.
Well, I've been building my car for about a year and a half now. I wanted to go kenne bell but have now decided to twin turbo. Should I go with the hpperformance kit? Or Hellion? Also I am not sure the ideal compression ratio I want to be at.8.5:1, 9.5:1? I have ported heads intake and exh side I got from a forum so I am not sure the cc of them to be able to match with piston size.
35anngt is offline   Reply With Quote
Old 04-27-2011, 10:22 PM   #2
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
Re: twin turbo build.
It all depends...What is the vehicle? What are the definite mods? What is the drivetrain combo? What are your goals?
-Will
Knight F Mohawk is offline   Reply With Quote
Old 04-27-2011, 10:23 PM   #3
Left a big chunk of that out sorry lol, its a 99 GT staying 2v.
Old 04-27-2011, 10:24 PM   #4
Turbo Kits for Ford Mustangs
Check it out....I know it's a single kit instead of a twin, but it's about as affordable as you'll find. The forward facing kits they've recently introduced should be capable of big power also.
Are you wanting to build a racecar that is as fast as possible....or do you want a street car that makes good power and is still fun?
-Will
Old 04-27-2011, 10:27 PM   #5
Built rear end 31 spine Detroit locker 3.73, rebuilt tranny, clutch, billet steel flywheel. Cobra alum shortblock, port n polish pi heads, crower custom grind cams, ss ex 1mm oversized valves, full bolt ons, tubular suspension, coilovers, will be mainly a track car but will want to take it on the street so good daily drivability. Would like to see around 500-600 roughly rwhp.
Old 04-27-2011, 10:30 PM   #6
Good detail.
I'd go w/ the 9.5:1 personally. It'll help you have a bit more low end and spool quicker, and it shouldn't present a problem w/ the power levels you are aiming for. It'll just make for a more fun street car.
I think you'll probably be fine w/ 3.73's, but remember that you don't need a lot of gear w/ a turbo setup.
Ported PI heads, crower cams, and a good shortblock should easily support 500-600. An extrude honed Bullitt Intake or Trick Flow manifold would be ideal...maybe even one of the P-51's (I have never seen one in person lol), but a PI intake would probably do the job
-Will
Old 04-27-2011, 10:32 PM   #7
I have been considering the forward facing kit from on3, not sure if that's the link you posted or not haven't looked yet but I assume so. Only reason I'm contemplating twins is I think I would have to run around 20 psi to be where id like it. Turbo life and efficiency will increase a lot more if I ran ten pounds each turbo rather than 20+ on a single. I was thinking 57mm's. Wouldnt have too much turbo lag, but still be good size.
Old 04-27-2011, 10:34 PM   #8
Twin 57's would definitely get you there!
-Will
Old 04-27-2011, 10:35 PM   #9
After my break in period the stocker is coming off I like both the p-51 and reichard racing intake but as with everything have heard negative things with both. Still have heard good things about the edelbrock. But I am not too worried about it. I also have a tfs plenum and 75mm tb up top.
Old 04-27-2011, 10:38 PM   #10
With my heads ported, intake and ex side. How much will that affect my compression ratio? I think 18cc dish would put me at 9.5:1 correct? How much could the cc be altered from the heads?
Old 04-27-2011, 10:44 PM   #11
Porting shouldn't affect compression ratio....gasket thickness and milling the heads would. You need to talk to your engine builder about that.
-Will
3.8 Twin turbo build! dwood63 Pre-2005 V6 Mustang 31 12-21-2016 03:57 PM
Twin Turbo 98StangGT 1979-1995 Mustang GT 3 07-12-2007 03:05 PM
Twin Turbo...? JaketheSnake Pre-2005 V6 Mustang 8 12-20-2006 11:16 AM
Twin Turbo PT Cruiser Seph The Bar 14 08-03-2006 11:47 AM
twin turbo or supercharger stanger04 Pre-2005 V6 Mustang 18 03-09-2006 06:28 PM
11:49 PM
