NEED HELP ASAP! - Mustang Evolution
Old 04-29-2011, 01:42 PM   #1
Topless04GT's Avatar
NEED HELP ASAP!
Hey guys... long story short.. fixing the trunk, threw her back on.. compleeeeeeetely forgot to rewire... close the trunk and now i cant get it to release. I have a vert... WTF do i do!!! im searching the net right now.. please help!
My girl... ehh, cars never leave you! stick to cars!
My name is Josh, Whats yours?
Topless04GT is offline   Reply With Quote
Old 04-29-2011, 01:47 PM   #2
Can't you go through the back seat and pull the emergency trunk release. I'm not familiar with verts, do they have an opening behind the rear seat?
11SHELBYGT500 is offline   Reply With Quote
Old 04-29-2011, 01:47 PM   #3
Re: NEED HELP ASAP!
i had to look up how to remove them in a vert... the seats dont fold down... im hopin to god it has a pass through in a convertible.. but osmething is telling me there isnt.
Old 04-29-2011, 01:50 PM   #4
You should be able to remove the rear seat altogether from the inside.
Old 04-29-2011, 01:54 PM   #5
Re: NEED HELP ASAP!
thats what i am tryin to do now.. except for my life i cant find this button under the bottom cushion. its drivin me nucking futs haha
Old 04-29-2011, 01:58 PM   #6
Not sure may be no button. Push the front of the seat down/ back/ and then pull up.
Alscobra is offline   Reply With Quote
Old 04-29-2011, 02:00 PM   #7
Re: NEED HELP ASAP!
Um....Isn't there a key hole in the trunk that you can unlock the trunk with your key old school manual key insertion way? Or did you shave the key hole?
Old 04-29-2011, 02:02 PM   #8
Re: NEED HELP ASAP!
shaved the keyhole... :/
Old 04-29-2011, 02:05 PM   #9
Re: NEED HELP ASAP!
That would make it tough then.
This is an 04 right? If so, the seats will come out from the inside without issue. The bottom cushions the button is tough to find, but it is there on each side...they are kind of in the middle of each seat section.
YOu will definitely be able to reach the trunk release from the back seat as it is open...you may have to keep your top up to do it though.
Old 04-29-2011, 02:40 PM   #10
Re: NEED HELP ASAP!
yea you will have to take out the back seat and then not sure if you can remove the protection shell thing to get into the trunk...
If you have to you can cut through that cover thing once you get the seats out then just replace it afterwards. The top will of course have to be up... and make sure you dont mess up the top motor or lines.
Old 04-29-2011, 02:45 PM   #11
Re: NEED HELP ASAP!
ok.. here was what i discovered... jesus it took me forever... but i didnt even have to remove the seats... just alot of putting the top up top down top up top down.. here is the process if anyone ever goes through this route
OK after getting pissed off because i had to get the stuff outta the trunk i realized i wasnt rationally thinking. I sat down drank some iced tea and thought it out... ok cant get in through the plug because we removed the lock cylinder... cant go through the back of the seats because there is no pass through.. wtf am I gonna do. then i was like ok I had the top down to be able to move a lot easier and said ok lets look at the situation with the top up... bam it hit me. pull the protective cover off. Picture 1:
Well **** still blocked... Picture 2
But wait... what is this sticking out? could it be... are the heavens opening up to me? why YES! there it is.. the plug i needed just sitting there waiting to be thrusted by its missing male counterpart!...
plugged it in.. popped the trunk.. all is well
If you want to lock this thread mod's be my guest lol... all is well in my world again haha
and thanks to all the quick help guys!!!!
Old 04-29-2011, 02:47 PM   #12
Oh ***** you got lucky
Old 04-29-2011, 03:31 PM   #13
Titus Wadicus
svtlx's Avatar
Re: NEED HELP ASAP!
lmao... i thought i was gonna have to come over there with my bfh.....
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-29-2011, 03:39 PM   #14
Big f?cking Hammer?
Old 04-29-2011, 03:53 PM   #15
Re: NEED HELP ASAP!
Interesting...I remember being able to see into the trunk with the seats out and top up....
At least you were able to get it open.
Old 04-29-2011, 04:06 PM   #16
Titus Wadicus
svtlx's Avatar
Re: NEED HELP ASAP!
Originally Posted by 11SHELBYGT500 View Post
Big f?cking Hammer?
that would be correct sir....
Old 04-29-2011, 04:06 PM   #17
LuvMyMustangGT's Avatar
Don't some convertibles have a trunk release button in the glove box?
LuvMyMustangGT is offline   Reply With Quote
Old 04-29-2011, 04:07 PM   #18
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
Re: NEED HELP ASAP!
Glad you go it fixed....this thread made me laugh
-Will
Knight F Mohawk is offline   Reply With Quote
Old 04-29-2011, 04:08 PM   #19
Titus Wadicus
svtlx's Avatar
Re: NEED HELP ASAP!
he had the button disconnected i think...
Old 04-29-2011, 04:10 PM   #20
Ok now I got it. I'm at work you'll have to excuse the lack if brain cells!
Old 04-29-2011, 04:17 PM   #21
Titus Wadicus
svtlx's Avatar
Re: NEED HELP ASAP!
i didnt think that, i just assumed u were on an iphone...
Old 04-29-2011, 04:27 PM   #22
You assumed correctly, lol.
Old 04-29-2011, 08:11 PM   #23
06mustangmike's Avatar
Re: NEED HELP ASAP!
i believe they do!
06mustangmike is offline   Reply With Quote
Old 04-29-2011, 08:18 PM   #24
Re: NEED HELP ASAP!
good job well thought through
Old 04-30-2011, 06:57 AM   #25
Re: NEED HELP ASAP!
no... there is no passthrough. When the seats are off on mine they have the motors and amps... then a thick *** piece of foam that wouldnt budge... later found out also that you can push that cover where my hand is at in the pictures, off. The only problem is they are held in with christmas tree's and they are tough as **** to push out backwards. lol
Need help asap buddykern 1996-2004 Mustang GT 18 11-25-2009 06:52 PM
Help ASAP Big_Eddy Pre-2005 V6 Mustang 11 05-04-2006 01:19 PM
need help asap reaper4stang Pre-2005 V6 Mustang 16 08-28-2005 12:30 PM
Need help asap Brent Pre-2005 V6 Mustang 7 05-22-2005 08:53 AM
need help asap!!! Monkey Pre-2005 V6 Mustang 17 06-20-2004 11:24 PM
04:13 AM
