Sporadic fuel pressure gauge - Mustang Evolution
Old 05-01-2011, 02:28 AM   #1
RedRoush's Avatar
Region: Arkansas
Angry Sporadic fuel pressure gauge
Can anyone help me out with a fuel pressure gauge prob? It stays almost maxed out while the car is running, with the needle just jumping.
RedRoush is offline   Reply With Quote
Old 05-01-2011, 02:32 AM   #2
Re: Sporadic fuel pressure gauge
What is the max the gauge reads?
93CobraGuy is offline   Reply With Quote
Old 05-01-2011, 05:01 AM   #3
RedRoush's Avatar
Region: Arkansas
The gauge isn't even on zero when the car is off. Its sittin on 60. When I start it it sits on about 80. And then it jus jumps from 80 to 90 constantly. Think my needle might have jumped the lil stop on the gauge itself?
Old 05-01-2011, 10:54 AM   #4
Titus Wadicus
svtlx's Avatar
sounds like u need a new gauge dude. i had one that did that, it was bad.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
need help with custom fuel rails, fittings, fuel pressure gauge tire Pre-2005 V6 Mustang 2 07-13-2015 03:32 PM
no fuel pressure ? Chasity 2005-2010 Mustang GT 12 06-30-2009 06:42 AM
Oil pressure gauge Scut95 1979-1995 Mustang GT 12 03-24-2008 07:08 AM
Extra oil pressure sender unit for press gauge wesoakes Pre-2005 V6 Mustang 10 11-19-2006 12:57 PM
10:32 AM
