Issues at idle - Mustang Evolution
Old 05-03-2011, 12:41 PM   #1
iwannagofast's Avatar
Issues at idle
i started my car up today, like any other day, and it sounded like it was cam'n. I look down at my AFR and its bouncing around between 10.3-11.5ish at idle. Took it out for about a mile and everything else seems ok, but any time the car is at idle its runnin crazy rich. I thought it could be the Idle Air Control so i unbolted it and cleaned it out, and nope car is still actin a fool. My next thought is the MAF is shot. Anyone have any other ideas on what it could be?
iwannagofast is offline   Reply With Quote
Old 05-03-2011, 02:57 PM   #2
Jamesgt08's Avatar
I am havin the same problem i changed out my idle air control as well. Im thinkin it is my MAF too.
Jamesgt08 is offline   Reply With Quote
Old 05-03-2011, 03:26 PM   #3
Stang.racr's Avatar
I got a push rod motor but I'm having the sAme problem and tries the same thing
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 05-03-2011, 04:50 PM   #4
Re: Issues at idle
I had the same problem on my car. Upon startup my air-fuel guage read 11.0-11.9, but stoich under normal driving conditions. My tuner said it had something to do with my upstream o2s being slow to respond. I replaced the o2s with ford replacements, and haven't had the problem since. Hope you problem is something simple like this as well. Good luck.
-Daniel
2000 Vert, 4.6 SOHC swap, old set-up intercooled s-trim @11lbs..New setup-5.0 stroker, stage 2 heads, kenne bell 2.2l with a 2.75"
daniel302 is offline   Reply With Quote
Old 05-03-2011, 06:21 PM   #5
Stang.racr's Avatar
Yeah well I'm about to go crazy and order a bunch of parts cause mine is getting worse. It runs perfect over 2k but every time I get in stop and go traffic it messes up and dies. I crank it go afew feet and when I stop it dies again so might as well pull the ol cc out
Old 05-03-2011, 07:10 PM   #6
Jamesgt08's Avatar
Have u tried cleaning the throttle body and MAF. Cuz ive bought a bunch of parts to only thing left for me i the MAF. I changed my cam and crank sensor since then it worked better but still dies only very few times. But yea it sucks.
Old 05-03-2011, 07:11 PM   #7
Jamesgt08's Avatar
When you barely put it in drive to go does it feel like it hesitates then you have to give it more gas to go?
Old 05-03-2011, 08:31 PM   #8
Stang.racr's Avatar
I have only cleaned my iac gonna clean maf tomorrow and steal a couple sensors one at a time off my parts car. Also gotta heat wrap the starter I'm getting tomarow cause this one should of latex more than four months
Old 05-04-2011, 10:33 AM   #9
Re: Issues at idle
Hoping its the MAF, easy solution. Ill have one of my gearhead pals check it out
Old 05-04-2011, 01:49 PM   #10
Jamesgt08's Avatar
Let me kno what happens if u change the MAF
Old 05-04-2011, 04:31 PM   #11
Look at all your vac lines I had the same issue would run like I had stage 3 cams till it warmed up or I got on it. Turned out there is a line that runs from on side to the other on the motor that is in use when you first start the car then it shuts off any holes in this line and it willl run like crap till its warmed up
usmcsni is offline   Reply With Quote
Old 05-04-2011, 05:51 PM   #12
Jamesgt08's Avatar
I agree check all ur vacuum lines to make sure no leaks.
Old 05-05-2011, 11:12 AM   #13
Re: Issues at idle
vacuum line totally would have over looked that good call, i plan on messin wit it later today, ill post my findings, if any
Old 05-06-2011, 09:03 PM   #14
Re: Issues at idle
Yep vacuum leak, fixed!
Old 05-06-2011, 09:47 PM   #15
Jamesgt08's Avatar
Cool which vacuum line was it?
Old 05-06-2011, 10:35 PM   #16
Called it
Old 05-07-2011, 09:28 PM   #17
Re: Issues at idle
i got a vortech s/c on it and it was the line from the diverter valve. $5.25 fix, love it
Old 05-09-2011, 04:47 PM   #18
Supersnake4.6's Avatar
No guy just happend to me it's a vac leak I when to autozone had them pull codes it said it was my mas but it's not believe me 175 bucks later look for the leak
Supersnake4.6 is offline   Reply With Quote
Old 05-09-2011, 05:00 PM   #19
Wow can't even read that post
Old 05-09-2011, 07:10 PM   #20
From iPhone I was going back in from break at work so I was typeing fast
You guys with idle issues (possible vacume leak) try this SpectorV Pre-2005 V6 Mustang 3 06-01-2010 01:28 PM
Hot start idle issues Scorpion1 Pre-2005 V6 Mustang 12 04-07-2009 04:58 PM
Doesn't idle down. Joe_SHO Pre-2005 V6 Mustang 7 02-12-2009 07:44 AM
Idle concerns 98GreenStallion Pre-2005 V6 Mustang 22 03-14-2005 09:40 AM
At idle ASSEMbler Pre-2005 V6 Mustang 14 08-07-2003 01:54 AM
12:30 AM
