how wide of tires - Mustang Evolution
Old 05-04-2011, 07:44 AM   #1
how wide of tires
i want wider tires on the back of my car and i was just woundering if you guys/girls had any idea what size i should get.
96mustangv8 is offline   Reply With Quote
Old 05-04-2011, 07:46 AM   #2
Hunter's Avatar
Re: how wide of tires
get 17x10. My cousin has a pair on his 95 and they look sexy. I am looking for a pair for my 95 as well.
_____________
Landis
Hunter is offline   Reply With Quote
Old 05-04-2011, 09:05 AM   #3
you have to consider rotation. If you dont care to rotate then you can go wider out back vs the front. If you want to stagger the sizes then make it worth while (as in go with a noticeable wider tire out back)
17x8 wide in the front with a 255/45/17 and a 17x10 out back with a 295/40/17 for example.
If you want to rotate then go with a 17x8 rim or a 17x9 rim. If you go 17x9 get 275/40/17 tires ONLY for them. If you want to go more narrow than that (smaller than 275mm wide) then go with a 17x8.
Old 05-04-2011, 09:41 AM   #4
2002Gt's Avatar
I have stock gt wheels with 255 40 17. It looks good
2002Gt is offline   Reply With Quote
Old 05-04-2011, 09:51 AM   #5
Tib
Tib's Avatar
My roush came with 18X9 in the front and 18X10 in the rear...running 265/35R18 in the front and 295/35R18 in the rear. fits great and looks amazing.
2003 Roush Mustang GT Stage 2 Package - Current 'Stang
1998 Mustang GT - Previous 'Stang
Tib is offline   Reply With Quote
Old 05-04-2011, 09:52 AM   #6
yea you can get great deals on stock GT wheels
Old 05-04-2011, 10:03 AM   #7
Tib
Tib's Avatar
exactly, I picked up a set of stock gt wheels for beater wheels with 4 almost new tires for a total of $300.
Old 05-04-2011, 10:19 AM   #8
I NEED a set for my car for time when I need the car aligned etc etc
Old 05-04-2011, 07:49 PM   #9
I got a set of 245/45/17 up front and in back a set of monster 315/35/17s
usmcsni is offline   Reply With Quote
Old 05-04-2011, 08:00 PM   #10
Send a message via Skype™ to Texastboneking
me. 305/35r16 front. 315/35r16 rear. and i still spin through two gears and chirp the third. stupid slick roads
Texastboneking is offline   Reply With Quote
Old 05-04-2011, 08:07 PM   #11
Yah I am a fan of 17x10.5" wheels with 315/35/17 tires.
18x10's are good too if you want the larger diameter wheel, but you lose that extra .5".
Either way they look badass on the stangs. Rotation is out of the question with those tires so keep that in mind.
Old 05-04-2011, 08:10 PM   #12
you can rotate side to side but it gets costly breaking down the tires everytime. good thing i work at a dealer lol
Old 05-05-2011, 05:02 AM   #13
ksrumbel's Avatar
Usually when you have 315s they are uni-directional. I don't know of any 315s that aren't. And did I read your other post correctly? You say you gave 305s in the front. Is that even possible?
ksrumbel is offline   Reply With Quote
Old 05-05-2011, 05:04 AM   #14
ksrumbel's Avatar
I think you gave all your sizes wrong if the tires are on the wheels that are on your car in your current picture. Let me know. I'm curious
Old 05-05-2011, 05:14 AM   #15
Tib
Tib's Avatar
295/35R18 Rear's...Pic shows that clearly
265/35R18 Front's...Kinda hard to make out in the pic but trying to help.
ID:	26611   Click image for larger version
Old 05-05-2011, 08:48 AM   #16
CodyNelson's Avatar
Region: West Virgina
I have 275/40/17s on my GT and it looks great! plus I can rotate them to get more wear out of them
Old 05-05-2011, 08:53 AM   #17
USAF_stang's Avatar
I've got 17x9 upfront and 17x10.5 in the rear
USAF_stang is offline   Reply With Quote
Old 05-05-2011, 09:55 AM   #18
i was wrong. i was going by what the guy that owned it before me said. htey are275 on the front. the rear was right. except they are 17 rim
Old 05-05-2011, 09:59 AM   #19
Chick Nasty's Avatar
Send a message via AIM to Chick Nasty
305/35-18s in the rear ............. 275/35-18s in front
Chick Nasty is offline   Reply With Quote
Old 05-05-2011, 10:05 AM   #20
heres the 315s on the 17x10.5
Old 05-05-2011, 10:11 AM   #21
also remember just because a tire says "315" or some other number does not mean they all are the same width there is no standard.
Old 05-05-2011, 10:16 AM   #22
USAF_stang's Avatar
wow, never knew that. Prob something they should do lol
Old 05-05-2011, 10:20 AM   #23
i had no idea....thought it was a measure of width in mm.... thought just the sidewall was a variable percentage based on width ...good to know!!!
Old 05-05-2011, 10:45 AM   #24
Yah this is true. My Sumitimo 315's are narrower than the 315 Goodyear F1 GSD3's (not made anymore). The outer lip of the rim is not protected at all. So the 315 in a Sumi might not be wide enough where a different brand 315 is.
Old 05-05-2011, 11:08 AM   #25
thanks for all your help guys
Old 05-05-2011, 06:34 PM   #26
My wife has 295/35-18 BFG's on 18x10's out back, 275/35-18 Toyo's on 18x9's up front.
I have 305/35-18 Toyo's on 18x10's out back and 275/35-18 BFG's on 18x9's up front.
I know...strange combination between cars...O well.
Nitto, Sumitomo are known to run narrow, BFG/Toyo/Goodyear and fairly close on sizes. Honestly, a 305 Toyo is a bit big for a 10" wheel. It definitely has some bulge.
Old 05-06-2011, 08:53 AM   #27
stangstar92's Avatar
315's
2002 Gt Mustang - Built 2 Valve
"Real cars don't power the front wheels...they lift them"
stangstar92 is offline   Reply With Quote
Old 05-06-2011, 09:11 AM   #28
the width is in mm's and all that is accurate but every tire maker conforms to its own standards so its not an actual 275mm or its measured in different places etc ets so two types of tires can be different width in reality even if they are the same size.
Old 05-06-2011, 11:45 AM   #29
USAF_stang's Avatar
Sumitomo High Performance HTR Z Tire (315/35-17)
On a 17x10.5 wheel
Old 05-06-2011, 06:12 PM   #30
On a 17x10.5 wheel
Those are what I have on my car...for some reason everyone thinks they are 18's. I've had a lot of people ask if the wheels are 18's...they do look bigger due to less sidewall compared to the fronts when on the car.
Old 05-07-2011, 04:53 AM   #31
USAF_stang's Avatar
this is all my dad would take...hoping he got them put on this weekend haha.
poor baby is so dirty from being neglected for 6 months
Wide body kit? HotRod.riguez Mustang Audio & Video 4 04-17-2008 07:44 PM
REVIEW: Firestone Firehawk WIDE OVAL's Zim Mustang Wheels & Tires 22 09-19-2006 06:28 AM
will 10 inch wide rims fit 95gt350 Mustang Wheels & Tires 2 01-05-2006 03:59 PM
pro's / con's on wide tires Exit_In_Red Mustang Wheels & Tires 7 03-20-2005 11:01 PM
how wide of a tire.... project232 Mustang Wheels & Tires 11 03-01-2005 08:26 PM
» Members Mustangs
Jolene
Ronin327
Lucy
Rawly
Add your Mustang
02:04 PM
