how to ? - Mustang Evolution
Old 05-04-2011, 08:03 AM   #1
how to ?
how do you remove the mustang on the grill it looks like a torx bit but it has that thing in the middle of the screw so i am lost at how to get it off lol
96mustangv8 is offline   Reply With Quote
Old 05-04-2011, 08:11 AM   #2
Titus Wadicus
svtlx's Avatar
Re: how to ?
it's called a "tamper proof" screw so u dont fuk with it....lol. ford put them on the mass air meters as well. u can go to any automotive parts retailer and pick up the appropriate bit to remove it.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 05-04-2011, 10:20 AM   #3
Tib
Tib's Avatar
Re: how to ?
yep or break off the post and use a regular torx bit.
2003 Roush Mustang GT Stage 2 Package - Current 'Stang
1998 Mustang GT - Previous 'Stang
Tib is offline   Reply With Quote
Old 05-04-2011, 10:22 AM   #4
Re: how to ?
the "BEST" way is to simply remove the front bumper to get to them, you can pry it back but thats just another way to go about it and VERY difficult to reinstall it that way, you can buy tamper proof torx bolts or what not at autozone.
06:09 PM
