aftermarket h-pipe question - Mustang Evolution
Old 05-04-2011, 12:00 PM   #1
mrc
mrc's Avatar
I tried searching for the answer to this but I had very little luck. I was wondering if you can use an after market H-pipe with the stock exhaust? I am wondering if they will bolt up to one another or do you need to have an aftermarket catback exhaust?
mrc is offline   Reply With Quote
Old 05-04-2011, 01:23 PM   #2
MustangMafia97's Avatar
Send a message via AIM to MustangMafia97
Re: aftermarket h-pipe question
You can easily install an aftermarket H or X pipe in the place of your stock catback H pipe. You can order an aftermarket H with high flow cats on it. The way you worded your question contradicts itself. Could you clarify if not answered?
Nothing but Ford...Nothing but American Muscle
MustangMafia97 is offline   Reply With Quote
Old 05-04-2011, 01:53 PM   #3
mrc
mrc's Avatar
Sorry if my question was unclear. You have stock exhaust manifolds then the stock h-pipe and then the stock catback. Can you replace the stock h-pipe with an aftermarket off road h-pipe well keeping the stock catback exhaust?
Old 05-04-2011, 02:17 PM   #4
the catalytic converters is located on the stock H pipe, whats after the stock H pipe is your mufflers. If you go with an aftermarket off road H pipe, you will have no cats left.
Old 05-04-2011, 02:25 PM   #5
mrc
mrc's Avatar
I know that. Can I change out the stock H-pipe to an aftermarket off road H-pipe with out needing to change out the stock catback exhaust? Can I keep all the stock piping after the new H-pipe or do I have to buy an aftermarket catback exhaust to mate the new H-pipe to?
Old 05-04-2011, 02:51 PM   #6
oh no, you can keep everything else. I just got done installing an off road x pipe on my car. Just switch out H pipe and your done, taking out the stock pipe is fun, i tell ya. Dont forget to soak down the exhaust manifold nuts holding the h pipe on to make it easier for ya. and getting to the bottom nut on the drivers side is not easy with the O2 sensor in the way.
Old 05-04-2011, 04:58 PM   #7
mrc
mrc's Avatar
Cool. Thanks for the help.
Old 05-04-2011, 07:47 PM   #8
Yes you can swap in an aftermarket h-pipe in place of your stock one. Keep in mind some h-pipes are made to work with longtubes only so make sure you order the regular sized pipe that'll bolt right up to the stock headers and not the shorty one.
Also, the off road midpipes eliminate the cats so you're going to trigger a cel for lack of 02 sensors. You'll need mil eliminators or a tune to clear that cel.
Quick question (X-Pipe) 03 Yellow Stang 1996-2004 Mustang GT 4 02-08-2010 04:52 PM
2002 V6 - H pipe or Y pipe for dual exhaust? AirBrontosaurus Pre-2005 V6 Mustang 26 12-18-2008 08:52 PM
aftermarket x pipe all8280bcc Mustang Parts for Sale and Wanted 2 01-08-2007 07:58 AM
Aftermarket alarm system and OEM keyless entry question Crispy Pre-2005 V6 Mustang 2 02-28-2004 08:36 PM
H pipe, X pipe, or true dual exhaust wiarumas Pre-2005 V6 Mustang 9 08-02-2003 10:09 AM
10:55 PM
