ok so hids or a blinker kit? - Mustang Evolution
Old 05-05-2011, 12:05 PM   #1
i have to pick between a set of hids or a blinker kit ? what one first i can get the other one next check so help me decide, and if hids what size are the bulbs 9004?
96mustangv8 is offline   Reply With Quote
Old 05-05-2011, 12:10 PM   #2
Las0mbra's Avatar
I'd do hids. More drastic of a change. And they are 9007s unless I'm mistaken
Old 05-05-2011, 07:02 PM   #3
03GT88's Avatar
Id say xenons because it is an actual upgrade. My 03 uses 9007. I'm about to get the bi xenons kit. So I can have a hi and lo beam.
Or flip a coin!
03GT88 is offline   Reply With Quote
Old 05-05-2011, 07:09 PM   #4
Re: ok so hids or a blinker kit?
What do you mean by blinker kit?
Old 05-05-2011, 07:11 PM   #5
03GT88's Avatar
Im guessing sequential
Old 05-05-2011, 11:16 PM   #6
Las0mbra's Avatar
Or flip a coin!
I have the bixenons. Theyre pretty much the same accept for a wiring harness and a slightly different bulb.
Old 05-05-2011, 11:24 PM   #7
Joshy's Avatar
What's the diff?
www.petom.biz
Joshy is offline   Reply With Quote
Old 05-05-2011, 11:32 PM   #8
Las0mbra's Avatar
Originally Posted by Joshy
What's the diff?
They have a little bigger body near the base where the wires come out of the bulbs to house a little thing that pulls the bulb in a little. Moving the light back makes the light refract differently making it like your factory high beams.
Edit: and the harness has a little power box that controls the high beam function. It's complicated to explain over the forum though.
Old 05-05-2011, 11:33 PM   #9
Joshy's Avatar
Ah ok
www.petom.biz
Old 05-05-2011, 11:38 PM   #10
03GT88's Avatar
So is there a noticeable difference when you switched from hi to low?. I have another car that uses a single bulb and it has xenons low an halogen hi and the high beam is similar to a dam candle.
Old 05-05-2011, 11:45 PM   #11
Las0mbra's Avatar
Yep, when you have hids, the glare is a little bad, so you have to angle the lights slightly down, which in turn lowers the ability to see far distances and around turns sometimes. You pretty much need the dual kit ( mines from ddmtuning and it's great btw )... The hi beams look just like the high beams with the regular bulbs. And when you need to flash someone at night, single beams won't do anything... And if you turn on high beams with only a low beam kit, theyll just turn off.
Blinker Lugazar7 Pre-2005 V6 Mustang 10 03-17-2011 08:16 PM
HIDs? Las0mbra Mustang Audio & Video 25 02-09-2011 10:58 PM
HIDS vs. Stock Bulbs Matt@StangMods Pictures and Videos 12 09-09-2005 09:38 AM
HIDs from a friend :thumbup: Dark02Pony Pictures and Videos 17 09-06-2005 10:52 PM
New HIDs installed Matt@StangMods Pictures and Videos 15 09-03-2005 01:13 AM
12:35 AM
