thinking about a super charger - Mustang Evolution
Old 05-09-2011, 11:21 AM   #1
Exclamation thinking about a super charger
this is were i need your guys help i dont no lot about these engines all i no is back on my old grand am i had to pretty much rebuild my hole engine lifters, vlves and springs all the good stuff, can these engines keep like 8 psi with or problem or just rebuild it ?
96mustangv8 is offline   Reply With Quote
Old 05-09-2011, 11:28 AM   #2
Re: thinking about a super charger
8psi is easily do able on 99-04 GT mustangs IF the tune is right.
Old 05-09-2011, 01:03 PM   #3
Kpd3014's Avatar
I have an 04 that has had the procharger PS1 HO kit on it since my brother bought the car new. 10psi and no problems at all. Of course with that being said we don't beat on his car everyday but it should be able to handle 8 easily.
2012 GT500 PP, NAV, SSW exhaust, BMR lowering springs
Kpd3014 is offline   Reply With Quote
Old 05-10-2011, 11:58 AM   #4
ColeJohnson's Avatar
Oh, good info. Along with holding 9PSI easy, what brands do ya'll suggest and whats a ballpark figure on price of the parts?
2016 Comp Orange GT (current)
Old 05-10-2011, 12:34 PM   #5
probably will cost you 6k give or take to get the kit and all parts, not counting labor
Old 05-11-2011, 01:18 AM   #6
Kpd3014's Avatar
I can only speak on prochargers because that is all I have had. If you like the whistle even at idle then they are the way to go. I like it when people roll down the windows and listen. You can actually see guys telling their wives, that thing is super charged. Like their wife cares..lol.
Old 05-11-2011, 01:19 AM   #7
Kpd3014's Avatar
Oh and price is most likely about 6,000 like previously mentioned.
Old 05-11-2011, 10:03 AM   #8
wereKEV's Avatar
they say a stock motor can handle 10psi no problem.
wereKEV is offline   Reply With Quote
Old 05-11-2011, 10:07 AM   #9
8-10 psi is a good range, it can take more but you'd be living on the edge risking a bad tank of gas or something.
It all depends on the tune like was mentioned. You can run 14 psi and survive if your tune is dead on. You could blow your motor on 6 psi if your tune is generic and not dialed in. So it all depends on the tune.
Old 05-11-2011, 10:07 AM   #10
yup but realize the tune is the MOST IMPORTANT part you cant just stick the one on that comes from say Vortech etc... it has to be tuned right, tuned safe not to the limit.
Old 05-11-2011, 10:09 AM   #11
wereKEV's Avatar
yeah mine is vortech I dont know about the tune it was there when I bought it.
Old 05-11-2011, 10:22 AM   #12
sounds like you should schedule a dyno session for a couple runs with an A/F check to see if you are rich, lean, good etc may have power on the table you are not aware of or the car could be dangerously lean etc.
Old 05-11-2011, 10:35 AM   #13
ksrumbel's Avatar
My friend and I found out the hard way. His tune wasn't right on his procharged 00 GT pushing 15lbs and he shot a rod through the block last week. Time for a built motor.
ksrumbel is offline   Reply With Quote
Old 05-11-2011, 12:08 PM   #14
Tib
Tib's Avatar
As for cost, if your mechanically inclined you can do the install yourself. Most of the companies provide the installation manual online for free that you could download and review before buying...that will save easily $1,000 in labor costs. As far as the kit it depends on which version you buy, satin or chrome, high output, ECU upgrade and all the other option. If you install yourself you can get as low as $3500 without the tune or go as high as $6000 with options and tune plus labor.
2003 Roush Mustang GT Stage 2 Package - Current 'Stang
1998 Mustang GT - Previous 'Stang
Tib is offline   Reply With Quote
Old 05-12-2011, 10:58 AM   #15
wereKEV's Avatar
I am so glad my car had all the motor mods on it when I bought it saves me a few grand but they did make me buy an extended warranty to cover the stuff under the hood.
Old 05-12-2011, 11:00 AM   #16
wereKEV's Avatar
Iwant to dyno my car but can't afford it and I don't know where to take it.
Old 05-12-2011, 02:05 PM   #17
get in with the local car clubs and the usually have a dyno day or so where you can get a couple pulls for cheap just to see what it makes and check the a/f
thats what i did, spend 40 bucks for 2/3 pulls with a club doing it.
Old 05-13-2011, 10:44 AM   #18
wereKEV's Avatar
thanks I will check that out.
Old 05-14-2011, 02:37 PM   #19
1bad01gt's Avatar
I've had a Vortech 9lbs on my car since 07, no problems at all. Just get it tuned good by someone, dyno would be even better than just with a programmer.
1bad01gt is offline   Reply With Quote
Old 05-14-2011, 03:24 PM   #20
You have stock internals? And how many miles did you have on your car when installed and how many miles does it have now?
Old 05-14-2011, 03:34 PM   #21
1bad01gt's Avatar
Yea bone stock except for stage 2 comp cams. Had around 45000 and have almost 70000 now. And not easy on it either. Would suggest a set of cams also. Usually a 2 valve car with a blower and bolt ons make around 370-385 HP at the wheels. Mine put down 414 and 383 tq on 93 octane.
Old 05-14-2011, 03:57 PM   #22
25k on a 400+ 2v blown. That's what I've been preaching this whole time. Nice.
Alscobra is offline   Reply With Quote
Old 05-14-2011, 04:15 PM   #23
1bad01gt's Avatar
Planning on doing a head swap and possibly a intake swap also to a trick flow set up. Should have 500 or more then.
looking for procharger or super charger saleenman 1996-2004 Mustang GT 5 11-27-2009 02:41 PM
Turbo or super charger??? Mustangbobby General Mustang Discussion 3 05-11-2008 12:25 AM
super charger on the cheap hottcobra General Mustang Discussion 11 01-07-2008 11:30 PM
Ran across this super charger Cajun JungleBoy Pre-2005 V6 Mustang 9 04-14-2006 07:14 PM
super charger question oaktonarcher Pre-2005 V6 Mustang 4 03-03-2004 03:37 PM
06:12 AM
