Fluidyne Radiator leak - Mustang Evolution
Old 05-09-2011, 05:13 PM   #1
bobsurvives's Avatar
Hey guys Im having a frequent problem with my car... I just recently bought and installed a fluidyne radiator all aluminum and it lasted as long a month and now its leaking this is the second time it's leaked from the same area! I had an all aluminum mishimoto and when it failed on me I thought it was defective so when I saw that this one leaked from the same area I was getting seriously concerned about my car I don't know if I have another defective radiator or my cars engine is causing an extreme amount of pressure to cause the radiator to leak... I experimented by releasing the pressure from the resivour (which is dangerous when hot) as I uncapped it you can here a good amount of air escaping after a normal school to home commute and after leaving it uncapped overnight the radiator didnt leak! Whats the problem? It isnt the hoses checked them and replaced them.
bobsurvives is offline   Reply With Quote
Old 05-09-2011, 05:17 PM   #2
Make sure the cap is good. Maybe just replace it. It may be building up too much pressure before it relieves. Also where is it leaking from? If it's hose connections, you may want to replace the hose and use better clamps. Do not reuse spring type clamps.
Alscobra is offline   Reply With Quote
Old 05-09-2011, 05:19 PM   #3
Wait... The cap itself will relieve pressure? I don't know much and I'm still learning so help me out and yes the hoses and clamps are new (:
Old 05-09-2011, 06:09 PM   #4
The leak is coming from one top corner and the bottom corners of the radiator core
Old 05-09-2011, 06:58 PM   #5
onesickstang01's Avatar
I have hears several instances like this with fluidyne radiators. Mishimoto has a no questions asked warranty though. Even if you get in an accident they will replace it. It would take extreme pressures to do what you are doing and i highly doubt that is the cause. Its probably just a coincidence
onesickstang01 is offline   Reply With Quote
Old 05-09-2011, 08:42 PM   #6
The caps are rated at about 14-16 psi I believe. Overflow tank will hold the excess. Any more pressure than that can do damage. I have a mischimoto and love it. The quality and price are way better than the fluidyne. Make sure the radiator is not in a bind when you install it. The hold downs should line up easily don't force them.
Old 05-09-2011, 09:31 PM   #7
Ok, I'll just give it another try with the new fluidyne that's coming in since this one is still under warranty from LRS, it's on it's way here and I just need to send this one back so they can ship it to Fluidyne and they'll find out what happened or what was the problem
Should I still replace the cap?
Old 05-09-2011, 10:00 PM   #8
These are pics if the mishimoto radiator problem I think I'm having the same problem with the fluidyne
ID:	26735   Click image for larger version
Old 05-09-2011, 11:10 PM   #9
Yeah. Replace it. It's cheap and worth a try.
Old 05-09-2011, 11:53 PM   #10
Ok, and should I get a mechanic to install it instead of me and a buddy doing it?
Maybe he can figure out what the problem was.... Maybe the whole system needs to be flushed out?
Old 05-10-2011, 12:03 AM   #11
Not really man. As long as it's not in a bind and not rubbing on anything it should be ok. I had to alter one of my top brackets for some reason because the misch didn't line up right. That should be it though. It doesn't take much to put a hole in one of the passages.
Old 05-10-2011, 12:33 AM   #12
Ok, I'll let you know how everything goes
Old 05-10-2011, 12:35 AM   #13
By the way what do I need to do to flush the entire engine of coolant?
2001 Cobra fuel leak (I know wher3e the leak is) badcrc General Mustang Discussion 2 12-27-2008 11:54 PM
exhaust leak mustangruss Pre-2005 V6 Mustang 22 12-10-2005 08:26 AM
3F3Furious leak Thomas91169 The Bar 22 11-09-2005 07:53 AM
coolant leak josh97gt Pre-2005 V6 Mustang 7 09-01-2004 10:38 AM
Fluidyne Racing Aluminum Radiator for CHEAP! Fender Mustang Parts for Sale and Wanted 0 06-03-2004 08:07 AM
10:50 AM
