Swapping to carbeurator setup...? - Mustang Evolution
Old 05-10-2011, 07:21 AM   #1
Lastoria24's Avatar
Send a message via Skype™ to Lastoria24
I was considering dumping my efi 4.6l 2V for a carb'd setup in my 01 5spd.
Emissions around here is a nightmare, and my lack of knowledge with tuning and any parameters within make it kind of a turn off for me. Hoping maybe i can get "collector" plates, and dump the electronics, since i'd be more comfortable with the whole setup.
Anyone have experience with this? What motors could i run that would bolt to my tr3650 and stock frame, etc....?
Id like to drag race, a lot, eventually, and still keep it streetable.
Lastoria24 is offline   Reply With Quote
Old 05-10-2011, 07:25 AM   #2
Lastoria24's Avatar
Spelling Carburetor correctly would be a good place to start.
What a ******.
Old 05-10-2011, 09:31 AM   #3
Titus Wadicus
svtlx's Avatar
Re: Swapping to carbeurator setup...?
they make a carb set-up for 4.6, but im sure it utilizes sum basic ecm electronics to run the ignition system, since they dont have dizzys.
your only other option would be a 302 or 351. but u would have to swap out your k-member, add a fuel line return, and im not sure if that trans would work or not... but you could swap that out for a t-5 if all else fails.
i know u dont wanna hear it, but for what it will cost you on the swap (even if you do your own labor) it would be cheaper to get your 4.6 runnig right.
j.m.o.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 05-10-2011, 12:27 PM   #4
Lastoria24's Avatar
Yeah, see, its stuff like that i wish i knew the details for.
Like, say i procharge my stock 4.6 2v, can i later upgrade to a 4.6 4v and run the same setup? Regardless of if i put a blower on or not, can i just buy a 4.6 4v and put it in? Do i need a pcm? Wiring?
Id kill to have some type of resource that explained it all. Im so in over my head i dont know if ill ever make my mind up on what to do.
Bleh.
Old 05-10-2011, 12:45 PM   #5
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
As someone who has dropped EFI for a carb setup, I'm going to advise against it. EFI is superior in almost every way (except maybe not being able to tune with hand tools, but that's probably debatable...).
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 05-10-2011, 09:31 PM   #6
Titus Wadicus
svtlx's Avatar
Bleh.
you do have a resource, its called mustang evolution...
i hear the wiring is interchangable between the two and pcm's as well. dont quote me on it, cause im pushrod guy and not a mod motor guy
Old 05-11-2011, 06:19 AM   #7
Lastoria24's Avatar
Really, it has been. I've learned a lot in the last month and its all mainly from the people on this site. So I'm incredibly grateful for everyone thats read all my rantings. : p
I dunno now, i think ill just do a Procharger and keep the rest stock for now. Maybe ill do some crazy motor swap once i blow it up or something. Fact that I can put on a very mild super charger, run low 12's, easily 11's with some other bolt ons and stuff, sounds very appealing to me.
Now i need to find the best package/price...
Old 05-11-2011, 09:43 AM   #8
Titus Wadicus
svtlx's Avatar
a used twin scew may be your best bet if your on a budget... that's wut i would do anyway. usualy u can find them on ebay from when ppl upgrade to larger units. you could prolly build a basic system for around 9-1200 i suppose if you do the install yourself and source all the parts.
swapping a 4.2 3.8boii Pre-2005 V6 Mustang 1 03-27-2011 08:31 PM
Help! Swapping a 2004 4.6 into 1996 HELP! fast8750 1996-2004 Mustang GT 0 07-03-2009 04:55 PM
swapping a C5 505danielm Pre-2005 V6 Mustang 2 01-05-2009 12:28 PM
swapping the rear from the 90 into the 64? fast64 Classic Mustangs 8 04-27-2006 10:13 PM
Swapping brakes Rellik Pre-2005 V6 Mustang 11 10-16-2003 07:06 PM
11:54 AM
