Bypass Valve - Mustang Evolution
Old 05-11-2011, 04:48 AM   #1
67mustang97's Avatar
Region: Vermont
Bypass Valve
When installing a Bypass valve on a supercharged car do you hook the Bypass vacuum to the positive vacuum or negative vacuum on the car? Thanks
Old 05-11-2011, 08:03 AM   #2
Re: Bypass Valve
The bypass should see both vacuum and boost. What kind of supercharger kit is it?
-Daniel
2000 Vert, 4.6 SOHC swap, old set-up intercooled s-trim @11lbs..New setup-5.0 stroker, stage 2 heads, kenne bell 2.2l with a 2.75"
daniel302 is offline   Reply With Quote
Old 05-11-2011, 10:03 AM   #3
Titus Wadicus
svtlx's Avatar
Re: Bypass Valve
wut? i have never heard of that... positve or negative vacuum. it doesnt really matter where bud, just tap into the vacuum tree and go. at the end of the day all the vacuums lead right back to the intake.
i would try to get the line as close to the intake as possible and keep the hose short so u get a quick response time. either way though, it will work on any vacuum port u find.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 05-11-2011, 01:43 PM   #4
Region: Vermont
Re: Bypass Valve
Thanks guys I wasn't sure if it's called positive and negative vacuum. Just some lines suck and some blow. It's a Vortech V3
Old 05-11-2011, 04:16 PM   #5
Re: Bypass Valve
Since it's a centri, like was said above, you can tee it into any of the vacuum lines.
-Daniel
where pcv valve on my 3.8L v6 valve cover to where? Pascullon Pre-2005 V6 Mustang 2 02-28-2011 08:47 AM
clutch bypass problem 90Stang_5.0 1979-1995 Mustang GT 4 12-29-2010 12:26 AM
Governor bypass Senorjizzy Pre-2005 V6 Mustang 17 02-15-2010 12:07 PM
Bypass valve & Blowoff valve sporter 2005-2010 Mustang GT 7 05-27-2007 02:57 PM
A/C bypass pulley chadderkdawg 1979-1995 Mustang GT 2 08-01-2006 08:22 AM
07:06 PM
