Any Ideas? - Mustang Evolution
Old 05-11-2011, 09:18 AM   #1
Randl114's Avatar
Any Ideas?
After some exhaust work I was feeling proud of my good sounding stang. I felt like with summer coming up I would do a few other things as preventative maintenence. I changed the thermostat and while at it I changed the temperature sensor located behind the thermostat housing. Now I have a cold start issue and the car runs rough for the first few minutes. The check engine light came on and the temperature gauge only goes up a quarter of the way. I know the engine has to hotter than that. Any Ideas what it could be. I havent had a chance to read codes with a scanner but wanted to see if any of you great minds might know what was causing this headache of mine.
Your enemy is doing what you can not. When you meet he WILL defeat you.
Randl114 is offline   Reply With Quote
Old 05-11-2011, 09:54 AM   #2
Titus Wadicus
svtlx's Avatar
Re: Any Ideas?
you coulda got a bad temp sensor... but u really need to read the codes, we're not magic here, you gotta help us out.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 05-11-2011, 10:57 AM   #3
StangSims39's Avatar
Re: Any Ideas?
Def scan the computer and see what those codes are, it will tell you right off the bat.
StangSims39 is offline   Reply With Quote
Old 05-11-2011, 11:00 AM   #4
Randl114's Avatar
Re: Any Ideas?
I dont think the codes will be related because of work from the weekend on exhaust. I removed cats so I think that is what the check engine light is for.
Old 05-11-2011, 11:06 AM   #5
Re: Any Ideas?
Did you get the MIL Eliminators? Or if you have an old flash on a tuner turn the rear O2 Sensors off?
Old 05-11-2011, 11:11 AM   #6
Re: Any Ideas?
Also try replacing the Temp Sensor with the one you took out, just clean it up a bit, and while you may have just had the exhaust done, you never know, these machines can act one way, but it really be another problem, with out the codes knowing for sure, its all speculation.
Any ideas? Jfoster 1996-2004 Mustang GT 0 01-05-2011 07:53 PM
need some ideas b-mac New Member Introductions & Greetings 4 08-11-2009 08:37 AM
any more ideas? machoman013 Pre-2005 V6 Mustang 1 08-14-2006 07:57 AM
ideas blue00v6 Pre-2005 V6 Mustang 13 04-28-2006 10:01 AM
Ideas??? 1Slow6er Mustang Audio & Video 3 05-01-2003 10:08 PM
07:36 AM
