Trans Heat - Mustang Evolution
Old 05-11-2011, 12:58 PM   #1
Randl114's Avatar
Trans Heat
Anybody having issues with floorboards heating up. I had to point the a/c vents towards the floor cause my leg was getting to hot. I thought it might be a catalytic converter issue, but since i have done away with the converters the floorboards still seem to be getting warmer then I want it to. Could this be caused by the transmission being hot. I checked the fluid and it doesnt appear or smell burnt and the level is right where it should be. I have heard from another mustanger in my area that my transmission is supposed to run a little hot. Anybody know about this?
Your enemy is doing what you can not. When you meet he WILL defeat you.
Randl114 is offline   Reply With Quote
Old 05-11-2011, 02:07 PM   #2
Re: Trans Heat
ive only heard of this if the insulation was removed~ has sit been?
Old 05-11-2011, 02:21 PM   #3
Randl114's Avatar
Re: Trans Heat
No it hasn't. Was just under it this weekend looking at everything and it all looks to be good as far as undercoating. As far as under the carpet on the inside it is all stock to the best of my knowledge.
No Heat dino.999 1996-2004 Mustang GT 5 02-06-2011 06:10 AM
heat shield Senorjizzy Pre-2005 V6 Mustang 2 10-10-2009 11:50 AM
TF Track heat GOTGREENS 1996-2004 Mustang GT 4 03-09-2008 01:33 PM
02:27 AM
