Upper control arm buahings - Mustang Evolution
Old 05-13-2011, 06:21 PM   #1
96 stang's Avatar
So I just got these new control arms & polyurethane bushings but I don't know if I'm supposed to pull out that sleeve that the old bushings were in or press these in to the sleeve & I don't know why it's 2 pieces because the other one wasn't like this. Does anyone know how I can go about doing this?
Thanks.
ID:	26859   Click image for larger version
96 stang is offline   Reply With Quote
Old 05-13-2011, 10:38 PM   #2
Redlsea's Avatar
Well if those are energy suspension bushings they are two piece and you need to take sleeve out and use the provided grease to lube the pin and hole because the factory bushings use the rubber bonded to the steel sleeve that twists then reruns to it's original position where as the poly urethane bushings only moving part is the steel sleeve in the bushing which is why you need to lube the sleeve. Also with the polyurethane bushing you don't have to tighten the through bolt in the bushings resting position either which makes for easier instalation
Redlsea is offline   Reply With Quote
Old 05-13-2011, 11:12 PM   #3
96 stang's Avatar
Okay thanks. Yes it is energy suspension bushings, I thought that might be how it works but the poly bushings fits very loose inside that poly sleeve. Will it fit tighter when it's all together?
Old 05-14-2011, 12:46 AM   #4
Redlsea's Avatar
Unfortunately the only vehicle I've ever used those bushings on was a 240 sx and the where only 1 piece bushings
Old 05-14-2011, 10:39 PM   #5
96 stang's Avatar
Okay well thanks anyways
Front and rear control arm hardware specs SilentNoise 1979-1995 Mustang GT 2 10-13-2009 07:51 AM
Control arm bolts? Tbird232ci 1979-1995 Mustang GT 2 03-19-2006 07:33 AM
upper/lower control arm install chipshot101 1996-2004 Mustang GT 4 07-27-2004 07:18 PM
Lower control arm bolts Monkey Pre-2005 V6 Mustang 1 07-15-2003 10:37 AM
01:14 PM
