Gearing on my 98! - Mustang Evolution
Old 05-14-2011, 02:06 PM   #1
98RedGT's Avatar
Gearing on my 98!
I have the stock gears in the rear end. I was wondering if I should go with the 3.73 or the 4.10?
Let me know
ROOM FOR IMPROVEMENT
98RedGT is offline   Reply With Quote
Old 05-14-2011, 02:26 PM   #2
Titus Wadicus
svtlx's Avatar
Re: Gearing on my 98!
a 4.88 would be great xtra punch, but you wouldnt get outa your driveway before u ran outa motor.... i think 3.73 would be a good choice i.m.o.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 05-14-2011, 02:31 PM   #3
1bad01gt's Avatar
3.73s are a great gear, kinda hurt your gas mileage on the street though. Will need to change the spedo gear also so your speed odometer works right.
1bad01gt is offline   Reply With Quote
Old 05-14-2011, 02:39 PM   #4
98RedGT's Avatar
Yeah 4.88 lmao and yeah on American muscle they sell the kit with ford racing 3.73 gears the speedometer calibrator and royal purple gear oil.
Old 05-14-2011, 03:05 PM   #5
1bad01gt's Avatar
Yea, I've done a lot of business with them. Good company to deal with.
Old 05-14-2011, 03:06 PM   #6
1bad01gt's Avatar
I would put a girdle on instead of the stock rear end cover while your in there anyways.
Old 05-14-2011, 03:29 PM   #7
98RedGT's Avatar
To make it shiny? Lol
Old 05-14-2011, 03:31 PM   #8
1bad01gt's Avatar
It makes the rear end stronger inside. Mines black so it looks almost stock.
Old 05-14-2011, 03:32 PM   #9
98RedGT's Avatar
I'm looking at them right now. Lol thanks for the idea
Automatic gearing ranebowcyxx Pre-2005 V6 Mustang 4 05-30-2006 09:03 PM
gearing and speed question 3.27 to 4.10 tedness Pre-2005 V6 Mustang 9 10-07-2005 06:49 PM
How much for 2001 v6 with re gearing ? cagedthought Pre-2005 V6 Mustang 22 02-24-2005 12:37 PM
03:59 AM
