Need exhaust leak help 98 GT - Mustang Evolution
Old 05-18-2011, 09:07 AM   #1
MikesChargedGT's Avatar
My car has a popping/ticking noise and smells like exhaust right next to the noise so I assumed it's the manifold gasket, any advice on how to go about changing it, seems more complicated then a 60s car was wondering if there was a trick so I can do it in my garage with as little nuckle busting and cussing as possible, thanks
"Too much horsepower is not enough"
MikesChargedGT is offline   Reply With Quote
Old 05-18-2011, 10:22 AM   #2
Re: Need exhaust leak help 98 GT
you need to get under there and locate the leak, it might just be a connection or a small rust hole etc. Once you find it let us know where it is.
I am not sure how hard headers are, not horrible I am sure but it wont be an easy area to work in no doubt.
Old 05-18-2011, 10:25 AM   #3
StangSims39's Avatar
not sure how tight the 98's engine bay is, its prolly just as tight as the 04's its a ***** and a half, not even going to sugar coat it, if its the drivers side (mine was drivers side) its a wee bit easier, but not much. the bolts are a pain to get to, but try to tighten them first before you go and get new gaskets, when i had my headers put in the stock gaskets didnt look that bad. i started to hear the same noise with my new headers, but the bolts just needed to be re-torqued, so try that first, if not then replace the gasket.
StangSims39 is offline   Reply With Quote
Old 05-18-2011, 11:03 AM   #4
Alright I'll slide under it today and report back, thanks guys
Old 05-24-2011, 12:49 AM   #5
Couldn't get in there really good but the noise turned into loud pulsing/throbbing and I'm running really lean on that bank.....
exhaust
Exhaust Leak Help 97_GT 1996-2004 Mustang GT 8 05-20-2007 11:49 AM
exhaust leak 98StangGT 1996-2004 Mustang GT 8 08-29-2006 03:38 PM
I have an exhaust leak... Ibanezplayer272 1979-1995 Mustang GT 19 12-15-2005 11:47 AM
exhaust leak mustangruss Pre-2005 V6 Mustang 22 12-10-2005 08:26 AM
exhaust leak Scorpion99 Pre-2005 V6 Mustang 1 03-27-2004 02:47 PM
11:52 PM
