Compression - Mustang Evolution
Old 05-23-2011, 10:59 PM   #1
96 stang's Avatar
Compression
What should my compression be in my 96 gt?? The engine is all stock.
Thanks
96 stang is offline   Reply With Quote
Old 05-23-2011, 11:00 PM   #2
Send a message via Skype™ to Texastboneking
Guessing you know how to do a compression test?
Texastboneking is offline   Reply With Quote
Old 05-23-2011, 11:03 PM   #3
96 stang's Avatar
Well I go to a vocational school & I was going learn tomorrow before school ends but I have no idea what it is supposed to be at.
Old 05-23-2011, 11:08 PM   #4
Las0mbra's Avatar
I looked and all I found was 9.3:1, but I would keep looking
Old 05-23-2011, 11:22 PM   #5
96 stang's Avatar
Alright thanks. My car has been shaking alot when it's cold & it smells like oil so I want to run a compression check on it just to see if that's it
Old 05-23-2011, 11:57 PM   #6
MikesChargedGT's Avatar
I also need to check my compression so when you get number pm me thanks
"Too much horsepower is not enough"
MikesChargedGT is offline   Reply With Quote
Old 05-24-2011, 05:49 AM   #7
Let the engine cool down. Pull all the spark plugs. Put the gauge on one cylinder and spin it over three times. Record the number. Repeat for all cylinders. All your cylinders should have about the same reading. Now do it again but before you put the gauge on squirt a little bit of oil into the cylinder. Record the results. If your numbers jumped way up then you have worn rings. It they only went up about 10-20 psi then it's normal wear. But if it jumps 30-60 psi then your rings need to be replaced. I also recommend disabling the fuel system while running the test so you don't fill the cylinders with fuel. It will give you more accurate results. Post your findings and I'll tell you how it looks
Old 05-24-2011, 07:56 AM   #8
96 stang's Avatar
Okay cool thanks I will
low compression mike92691 Classic Mustangs 17 12-22-2010 09:00 AM
Non Pi to Pi compression iwannagofast 1996-2004 Mustang GT 12 12-30-2009 10:26 PM
what's an ideal compression ratio I_luv_HP&trq Pre-2005 V6 Mustang 15 10-16-2005 06:19 PM
compression Js281GT 1996-2004 Mustang GT 17 01-10-2005 05:01 PM
Compression questions. Horse Pre-2005 V6 Mustang 5 06-15-2004 05:01 PM
02:33 PM
