Performance and 1/4 mile - Mustang Evolution
Old 05-23-2011, 11:55 PM   #1
MikesChargedGT's Avatar
I was playing around with an app and I consistently say 6-6.5 0-60 trying hard not to get wheel spin, 1/4 mule was averaged at 14.51 @ 103 trap speed seems high for that time, short shifter supercharged 4.6 10psi I believe and I put stock exhaust on to smog, what do you guys think and how can I improve? Also I am leaning out I'm running 35-40 lbs of pressure in the fuel system I heard I need to be around 60. Any advice/help will be much appreciated thank you and sorry for the lengthy post
"Too much horsepower is not enough"
MikesChargedGT is offline   Reply With Quote
Old 05-24-2011, 04:00 AM   #2
ksrumbel's Avatar
My advice would be to take it to the track and see what you run. 14.5 is really high if you are supercharged. You are also right about the trap. Seems high for the time. My best was a 13.78 @ 102 and I just have a full exhaust, CAI, and 4.10s. If you can get traction you should be in the high 12s to low 13s
ksrumbel is offline   Reply With Quote
Old 05-24-2011, 08:42 AM   #3
stampde's Avatar
Re: Performance and 1/4 mile
I run 12's with a bolt on car , you should be able to break an 11 with a S/C car all day long ...... prob trap 110 - 115 mph
2011 GT Auto
Old 05-24-2011, 09:19 AM   #4
Well the 98s are way underpowered aren't they? And I got a pump that's running lean which is probably robbing power
Old 05-24-2011, 09:26 AM   #5
stampde's Avatar
sure is , you need fuel man !!!!!!
2011 GT Auto
Old 05-24-2011, 10:38 AM   #6
ksrumbel's Avatar
How much motor work? Heads/cams??
Old 05-24-2011, 11:48 AM   #7
Send a message via Skype™ to Texastboneking
Curious. What app are you playing with??? Pocket dyno?
Texastboneking is offline   Reply With Quote
Old 05-24-2011, 12:45 PM   #8
stampde's Avatar
03 Mach 1 , bolt on's ... as in 4.10's , off road pipe ,cat back exhaust , pulleys , JLT cold air ,and a tune ............ NO heads,No cams ,NADA
I'm also a drivin' fool
2011 GT Auto
Old 05-24-2011, 12:47 PM   #9
stampde's Avatar
didn't know it was a 98 , sorry ,,, for some reason i was thinking 3 valve car
ya that car probably only put down about 185 rwhp stock , and the blower probably put you up around 300 with a good tune ,still should go 12's
2011 GT Auto
Old 05-24-2011, 12:49 PM   #10
ksrumbel's Avatar
Ok. Didn't know it was a Mach
Old 05-24-2011, 01:07 PM   #11
How bad is it for the engine if I'm running lean and how much power does it rob?
Old 05-24-2011, 01:13 PM   #12
stampde's Avatar
its not good for the engine , if you lean out under boost you can cause serious engine damage , as in burnt valves , melted pistons etc ....
2011 GT Auto
Old 05-24-2011, 01:14 PM   #13
+1
Old 05-24-2011, 02:48 PM   #14
That's what I thought but my step dad said it's fine as long as I don't drive it like a muscle car, it has become inconvenient and my lead foot itches
Wareshoals 1/8 mile? 97Stallion The Bar 11 09-23-2004 10:57 AM
12:41 AM
