Help please!!!! - Mustang Evolution
Old 05-24-2011, 06:02 PM   #1
MikesChargedGT's Avatar
Help please!!!!
I'm running lean codes for the passenger side bank I think it's the pump I'm running 35 psi and it's a supercharged gt, but if it was wouldn't both banks be lean? Pulsing throbbing coming from that side, o2 sensor? Leak? Pump? Filter? Help please
"Too much horsepower is not enough"
MikesChargedGT is offline   Reply With Quote
Old 05-25-2011, 10:28 AM   #2
Re: Help please!!!!
Are you getting any other codes? Fuel psi at idle should be around 39-41psi. It is odd that you are only getting lean codes from one bank. When was the last time you changed the fuel filter? It's a cheap enough place to start if the only codes it's throwing is the bank 1 lean code.
-Daniel
2000 Vert, 4.6 SOHC swap, old set-up intercooled s-trim @11lbs..New setup-5.0 stroker, stage 2 heads, kenne bell 2.2l with a 2.75"
daniel302 is offline   Reply With Quote
Old 05-25-2011, 10:32 AM   #3
Send a message via Skype™ to Texastboneking
Re: Help please!!!!
35 psi at idle is not that bad. usually when you only have one bank lean you have a vacuum leak on that side.
Texastboneking is offline   Reply With Quote
Old 05-25-2011, 11:17 AM   #4
Re: Help please!!!!
Okay, thanks guys I'll look into it would an exhaust manifold leak cause it? Or? It went from a ticking on that side to a pulsing/throbbing
Old 05-25-2011, 11:18 AM   #5
Re: Help please!!!!
For my car I heard pressure needs to be higher then 45
Old 05-25-2011, 12:05 PM   #6
Re: Help please!!!!
35 for idle is fine for idle. just for idle. can you see what it goes to when you accelerate? and no. unless its a major exhaust leak it will not show lean. usually its in the air intake manifold area area.
Old 05-25-2011, 12:09 PM   #7
Re: Help please!!!!
It reads at 35-38 under wot
Old 05-25-2011, 12:15 PM   #8
Re: Help please!!!!
lol ok that number is low. how many miles on your car? when was the last time the fuel filter was changed? if recently then your pump aint puttin out
Old 05-25-2011, 02:46 PM   #9
94k miles but the pump died and was changed with a 4 cyl focus pump tho for some reason the owner cldnt dish out 250 for a decent walbro
Old 05-25-2011, 03:25 PM   #10
Lol sounds like you figured the problem out
Old 05-25-2011, 09:29 PM   #11
Re: Help please!!!!
Yeah but theres also a T-rex inline and seems to be running an okay amount of pressure but i do have a huge exhaust leak right before the 02 sensor it might be a false lean........just cant get it apart to replace the gasket.
Old 05-25-2011, 09:52 PM   #12
It's possible that it can cause a lean code.
Old 05-26-2011, 12:06 PM   #13
Yeah, my engines running okay but I'm only doing a 6.1 0-60 with my best launch that seems a bit slow
05:23 PM
