Have a quick question, installing H&Rs - Mustang Evolution
Old 05-26-2011, 04:35 PM   #1
Hi,
My friend has an 03 gt, he needs to know what size the bolts are to lower the rear drive shaft. They are the bolts right behind the brake disks.
He thinks its 20mm, but isnt sure and doesn't have anything that fits so he needs to go buy a wrench.
He needs to get the drive shaft lowered so he can replace the springs (as Im sure many of you know)
Thanks!
Nocturnal7x is offline   Reply With Quote
Old 05-26-2011, 05:24 PM   #2
Jamesgt08's Avatar
I didnt take my drive shaft off or the rear end off to install my springs.
Jamesgt08 is offline   Reply With Quote
Old 05-27-2011, 02:34 PM   #3
Re: Have a quick question, installing H&Rs
spring compressors? if no how did you do it?
Thanks!
Old 05-27-2011, 05:57 PM   #4
onesickstang01's Avatar
There are right upa all ovee the internet. Let rear end hang by lifting car by body. Get jack under one side of rear end and raise until it starts to push the other side up somewhat. Basically you want to compress one side and let the other open up completely. Then pry the spring out carefully. I usually tie a rope around the spring so that if it flies out it cant go too far
onesickstang01 is offline   Reply With Quote
Old 05-27-2011, 06:10 PM   #5
Jamesgt08's Avatar
I just use spring compressors. Lift up the carfrom the body and compress springs. Ima do mine on monday i can take pics.
Need Help Installing New Aftermarket Head Unit and Subs with Amp! 99supercharged Mustang Audio & Video 8 04-15-2010 11:57 PM
quick question jonbean Pre-2005 V6 Mustang 1 07-16-2009 03:48 PM
i got a quick question yoast88 1996-2004 Mustang GT 3 01-16-2009 04:26 AM
Quick question Scut95 The Bar 4 02-29-2008 10:58 PM
FOR SALE B&M Quick Silver Shifter TNTFowler Mustang Parts for Sale and Wanted 0 10-30-2006 06:46 PM
08:47 AM
