Need help - Mustang Evolution
Old 05-27-2011, 12:50 PM   #1
Jamesgt08's Avatar
Need help
Well last night my transmission went out. Im wondering if a transmission off a v6 will fit my v8??
Jamesgt08 is offline   Reply With Quote
Old 05-30-2011, 04:01 AM   #2
Army_DragRacer's Avatar
Re: Need help
the gear ratio isnt going to mesh up v6 to v8, i dont kno why youd even want to put a v6 transmission into a v8
Army_DragRacer is offline   Reply With Quote
Old 05-30-2011, 01:47 PM   #3
stangstar92's Avatar
It definitely wont be able to handle the power of a v8
2002 Gt Mustang - Built 2 Valve
"Real cars don't power the front wheels...they lift them"
stangstar92 is offline   Reply With Quote
Old 05-30-2011, 01:53 PM   #4
Send a message via Skype™ to Texastboneking
Re: Need help
lol if you do that you might as well look for another tranny. the v6 tranny cant hold that much power and will fail the first time you get on it
Texastboneking is offline   Reply With Quote
Old 05-30-2011, 08:34 PM   #5
BayyGT's Avatar
My dad is running a 4r70w from a 2000 v6 in his 72 mustang with manual valvebody and a 4k stall converter and it's holding up real well.
BayyGT is offline   Reply With Quote
Old 05-31-2011, 11:31 AM   #6
98gtdriver's Avatar
Re: Need help
IMO i would go to your local pull apart and try to find a v8 tranny. You dont want to risk putting a lighter duty v6 tranny on your v8. There will be a lot going wrong if you decide to go that route and will end up costing you more money
98gtdriver is offline   Reply With Quote
Old 05-31-2011, 11:54 AM   #7
Jamesgt08's Avatar
Ok thanks guys. Ima go look for a v8 tranny today or tomorrow. I miss driving my stang. What do yall think a good price is for a used tranny?
Old 05-31-2011, 12:33 PM   #8
Re: Need help
not 96+ it wont the T-5 was used in the v6 up through 04 then they swaped, not sure about that but you cant use a T-5 or visa versa.
Old 05-31-2011, 08:49 PM   #9
Re: Need help
Yah if it's a manual it is different, but I believe the same 4R70W was used in the 96-04 v6's, GT's and Mach 1's. So in that case an auto transmission would work, unless the bellhousing pattern is different, might want to check into that. The AODE was used on the 94-95 v6's/GT's.
Old 06-02-2011, 02:53 AM   #10
Actually the v6s bell will only bolt up to the 94/5 5.0 cars. The 4r was used in all 96 &up cars, but the Machs have a 4r75w. (I think)
98GT- CAI,Steeda Tri-Ax,o/r H, Underdrives, toon, more to come!
94V6- CAI, true duals, underdrives. the playtoy
i973eat1 is offline   Reply With Quote
Old 06-02-2011, 09:13 PM   #11
Re: Need help
Yah that could be true...I wasn't 100% sure about the fitment between years and models. I remember hearing something about the Machs having a different auto trans. but I found it hard to believe Ford doing so, as it probably wouldn't have been cost friendly.
10:06 PM
