Stupid aluminum heads - Mustang Evolution
Old 05-29-2011, 11:11 AM   #1
USAF_stang's Avatar
So before I left for Afghanistan blew a spark plug outta my head on the passenger side..let the dealership fix it...3500 later had a new head...did the same thing yesterday to the driver side...$6 later re-tapped it and put a sleeve in, no vacuum leak or anything and runs like a champ again..just figured I'd share this since I know these heads are notorious for this.
USAF_stang is offline   Reply With Quote
Old 05-29-2011, 11:15 AM   #2
wereKEV's Avatar
Re: Stupid aluminum heads
Thanks for the heads up.
wereKEV is offline   Reply With Quote
Old 05-29-2011, 11:22 AM   #3
USAF_stang's Avatar
no problem. I know stuff can get expensive and the cheaper way isn't always a bad way. Just need a little patience. But here's how we did it.
Re-tapped the spark plug hole with a bigger size (there's a certain tool for it I'll look up the name later), then took an old spark plug and put some antiseize on the spark plug, put permanent locktite (red) on the outside threads of the sleeve, tightened it down til you feel the sleeve pop and then bite into the head, back out the spark plug, put on the new ignition coil (it more than likely exploded like mine did if it blew out) then put all back together turn it over and check for air coming out.
*also turn the motor over til the piston is down before you tap it.
*start it for a few sec after you tap it to blow all the excess crap out.
hope this helps anyone that has this problem in the future
Old 05-30-2011, 09:41 AM   #4
Beav's Avatar
This just happened to Mustang Fan...
07 Roush 427R, Brembo 14" rotor and four piston calipers
05 GT Mustang, FRPP, FR X pipe, Hurst short throw,
American Racing Torque Thrust 10X20 wheels,
Granettelli tower brace, custom painted flat black grafix, Yellow Optima
Beav is offline   Reply With Quote
Old 05-30-2011, 05:06 PM   #5
USAF_stang's Avatar
hopefully he saw this before he bought a new head or paid someone to screw it up and THEN bought a new head
Old 05-30-2011, 05:17 PM   #6
Beav's Avatar
He had a dealer retap it I think for around $300...
Old 05-30-2011, 10:51 PM   #7
Twit38's Avatar
Ugh, this happened to my car, but as far as I know it didn't damage the head I hope. We did the rest of the stuff u said but now my car is still running like ****..i don't know how to explain what it's doing but it's like it dosent wanna run in 5 gear at all and when accelerating it jerks back and looses power and acts like it's not getting power..theres so vacuum leak and we changed the egr valve or what ever it's called...they said it takes a while for the computer in the car to relize we fixed the problem and to run right but I don't think that's working...I've been driving it for a week now and it still won't run any better..plus the check engine light keeps coming on and it says there's a miss but all spark plugs are new with new boots and all are re threaded and what not!!! Idk what the he'll is wrong with my car but I'm
Scared there's Somthing really wrong that I'm not gonna be able to afford to fix..
I'm a angel in ariat boots and a devil in blue jeans. I'm every cowgirls nightmare and every cowboys dream
Twit38 is offline   Reply With Quote
Old 05-30-2011, 11:14 PM   #8
hahah heads up...funny since it's involving heads....ohhh nevermind....
2008Shelby is offline   Reply With Quote
Old 05-31-2011, 11:33 AM   #9
wereKEV's Avatar
I never thought of that when I replyed I didn't know I was that witty.
Old 05-31-2011, 12:34 PM   #10
i need to double check my tq on my plugs and check them but I dont want to remove them unless im changing them
Old 05-31-2011, 07:46 PM   #11
USAF_stang's Avatar
Mine did the same. Have someone cancel all your error codes...haul *** and see if it cuts back on and runs fine. That's what I did. Sorry forgot to mention that.
Old 06-02-2011, 12:51 PM   #12
Twit38's Avatar
thanks! my dad took it to work to have someone clear any codes its throwing. Its running a little better now had to change a hose that was sucking shut. it Helped alot! but still can tell its not running its best. only if cars could talk and tell us whats wrong lol
Old 06-05-2011, 10:00 AM   #13
USAF_stang's Avatar
nooo prob. i'm surprised no1 had brought this up before lol
79-93 Be Cool Aluminum 2-row radiator w/ aluminum cap fast64 Mustang Parts for Sale and Wanted 6 07-22-2009 03:14 PM
Stupid Stupid Bonds bluemustang The Bar 8 02-07-2007 10:39 AM
Aluminum heads powerhungry966 1979-1995 Mustang GT 10 11-29-2006 09:13 PM
FS: BV Heads, 173's,Cam, and Stock Heads petrey10 Mustang Parts for Sale and Wanted 4 06-27-2006 12:15 AM
Aluminum Pullies 95stang_man Pre-2005 V6 Mustang 2 02-12-2005 05:03 AM
06:39 AM
