two problems..believe one causes the other. - Mustang Evolution
Old 06-04-2011, 06:36 PM   #1
ok 1998 mustang gt....long storys short here.....
my parking brake sucks....i can yank it totally up with no resistance until you hit the last 3 clicks then it barely has any....3 buddies can push her with ease with brake fully up....how do i fix this...what is wrong?
next
just replaced brakes full rotors and pads front n back....my back brake is whining i mean screaming at point on the high way and sharp turns, non at lower speeds minus turning ...it stops when i barely hit the brake then starts when off....i can see wear on the front of the rotor and thats all....the front feels rougher than the back by a long shot like the pad is constantly engaged.....i took the car out and hit the breaks (60-10mph) a few times and it seemed to stop for now....could it be the above problem doing this....no other brake has this problem...any ideas.
We have a full shop on base so lifts and tools are not a issue just "helpers".
thanks
-ED
eddie1 is offline   Reply With Quote
Old 06-04-2011, 07:24 PM   #2
Re: two problems..believe one causes the other.
Sounds like you didnt put something back together. WHere are you located?
Old 06-04-2011, 08:31 PM   #3
Update....took It out...and at highway speeds itll whine...if I press the brake slightly it stop and on bumps it stops
Im at sheppard afb
Old 06-04-2011, 08:35 PM   #4
Send a message via Skype™ to Texastboneking
mustangs are bad about this. mine does the same thing. if it is that bad take the pads out and buy some squeal stopper and spray the back of the pads with it. it will usually fix the squeal. also if your rotors are grooved then i would get them machined
Texastboneking is offline   Reply With Quote
Old 06-04-2011, 08:42 PM   #5
This..Also with parking brake make sure it is hooked up right. Nothing came loose, or a clip didn't come off. If remember right you can adjust it.
Old 06-04-2011, 08:47 PM   #6
Im at sheppard afb
Btw the clips r not on the pads
Old 06-04-2011, 08:59 PM   #7
well you will want the brake hardware shims. those help stop the vibration. if you dont have the shims on
Old 06-04-2011, 09:12 PM   #8
Im at sheppard afb
Was wondering where was see if close to me..Well people i know.
The clips are not. But I was worried about issue with parking brake, You should be able to adjust it. So when set it, it don't let the car move.
WHat kind of pads and rotors are you using? If reused stock rotors did you have them turned?
Old 06-04-2011, 09:49 PM   #9
Also parking break was like that before the break change
I know it dragging cuz I can smell brake real bad from the wheel
Old 06-04-2011, 09:55 PM   #10
Also everything is brand new...never did this before....i can also puah the car easly but the amell and whine n brake dust r only that one tire
Old 06-04-2011, 10:48 PM   #11
did you replace the slide pins and put high temp grease on them? if you didnt it will drag the brakes and cause them to burn
Old 06-04-2011, 11:19 PM   #12
i did not.....the shops open monday...i will try this and anti squeak spray....
any other idea before i tear her down again
Old 06-04-2011, 11:23 PM   #13
i did not.....the shops open monday....i dont have the cash to replace but i could afford the grease....
take the pins out of the caliper bracket. clean all the grease off of the pins. if they have rust on the pins clean it with a fine sandpaper or emery cloth. put the new high temp grease on the pins and slide them in and out of the bracket. should be a pretty smooth and free sliding movement. if it gets caught or hangs in a few spots then you will most likely need to replace those pins.
Old 06-04-2011, 11:26 PM   #14
ok i will deff do this....could you explaiin why only the front pad(not the one on piston) is dragging and not both? you can clearly tell the reas not bby the way the rotors feels compared to the front side.
also why barely hitting the brakes make it stop?
i like to learn for future referance
Old 06-04-2011, 11:35 PM   #15
the pads squeal when they are barely touching the rotor because of a slight vibration. when you apply just a small amout of pressure you are taking away any slack in the break pads and canceling the vibration. and the wear can happen on one side of the rotor faster than the other. this is usually a sign of seized components. like your pins not being able to slide freely in the bracket
Old 06-04-2011, 11:45 PM   #16
cool...thank you i will take it apart and do what you said and i will be back here when i do so for more problems or thankings.
thank you
Old 06-05-2011, 10:08 AM   #17
wereKEV's Avatar
You don't have a froze caliper do you I had a car once and the front caliper was froze and was'nt opening up I had to replace both front caipers.
wereKEV is offline   Reply With Quote
Old 06-05-2011, 10:24 AM   #18
i never had this problem before untill brake change...i will check for that also b ut when i turned them in to install they had very little resistance and moved smoothly
Old 06-05-2011, 10:30 AM   #19
wereKEV's Avatar
if they moved smoothly then they are fine , it was just a thought.
Old 06-05-2011, 10:54 AM   #20
Beav's Avatar
I'm thinking you need to check out your e brake problem, you might be right, could be same problem...
07 Roush 427R, Brembo 14" rotor and four piston calipers
05 GT Mustang, FRPP, FR X pipe, Hurst short throw,
American Racing Torque Thrust 10X20 wheels,
Granettelli tower brace, custom painted flat black grafix, Yellow Optima
Beav is offline   Reply With Quote
Old 06-05-2011, 10:56 AM   #21
wereKEV's Avatar
You can't be too safe when it comes to brakes make sure you check out everything.
Old 06-05-2011, 11:00 AM   #22
Beav's Avatar
You are so right....
Old 06-05-2011, 12:56 PM   #23
ima getter on the lift tom...i'll update after
Old 06-06-2011, 10:06 AM   #24
wereKEV's Avatar
I hope you get it worked out.
Old 06-06-2011, 10:44 AM   #25
This is an issue from Ford, there is a fix for it, not sure exactly but it might even be a Recall (ford will fix) TSB ford wont as its time is past~
Old 06-06-2011, 10:45 AM   #26
give me the vin and i will search recalls and tsbs for you
Old 06-06-2011, 05:03 PM   #27
1fafp42x6wf126866...or.....lfafp42x6wfl26866...i dunnop if l is a 1 or l....but there they are...
i believe i found the problem to the parking brake.....i took the center consol off today...and i took a look at the lever assembly....the pulley the the cable wraps around is split/bent down the middle were the two halfs connect and the cable get stuck in between the two halfs...i can push the cable out the grove and the brakes and tension on the lever are normal if i yank it and dont remove it it back out the brakes r locked and no tension on handle.
doesnt help much that the bolts connecting the lever are dry roting out and prob will rip out if i use the e-brake but regardless i believe the pulley issue is the problem and i'll just live without using the e-brake but once in a blue moon i guess...F^&# the ohio winters and there massive use of salt.
i'm getting her on the lift tom so i'll grease the slider pins and such and test her out.
Old 06-11-2011, 12:09 PM   #28
Slider bolt was so rusted up that it took a hammer and a vice and lots of swings to even break her loose but after that got her out cleaned. Lubed and new boot and works like brand new
Thanks for all the help.....
Ed
Old 06-11-2011, 07:35 PM   #29
Beav's Avatar
Glad you got her fixed...
Old 07-27-2015, 07:11 PM   #30
[QUOTE=eddie1;906310]ok i will deff do this....could you explaiin why only the front pad(not the one on piston) is dragging and not both? you can clearly tell the reas not bby the way the rotors feels compared to the front side.
i like to learn for future referance[/Q
caliper slides are bound up very commen problem on these cars.usually the right rear.you can get complete hardware kits from autozone around $10.reason outside pad dragging is from bound up caliper,piston retracts and pulls inside pad where it belongs,outer doesn't move. and drags rotor
don't put the anti-squeal on pads,only a crutch for wannabee tects,fix the problem and chamber the leading and trailing edge of pads free up caliper will fix all including e-brake adjusts itself every time you pull handle unless bound up
ALLYDRIVER1 is offline   Reply With Quote
Old 07-28-2015, 12:16 AM   #31
Mile high JDF's Avatar
Um this thread is 4 years old now
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 07-28-2015, 12:34 AM   #32
natestang07's Avatar
He is pro at digging up old threads
Old 07-28-2015, 01:47 PM   #33
there is one like u on every board,might help someone else is reason i posted the fix
Old 07-29-2015, 02:20 AM   #34
bucko's Avatar
Uncalled for comment.
In the future, if you have a fix to an issue that you come across in an old thread, please create a new thread with the suggested solution.
problems! znpzmustang Pre-2005 V6 Mustang 4 05-17-2011 01:59 PM
87 problems 87lx50 1979-1995 Mustang GT 9 03-18-2007 05:36 PM
more problems charkelly9 Mustang Audio & Video 18 05-19-2005 07:22 PM
a/c problems Warfire80 1996-2004 Mustang GT 6 11-29-2004 04:52 PM
Problems: Smokedya95stang ME Site Help & Announcements 0 03-06-2004 06:51 PM
06:33 AM
