Need help! - Mustang Evolution
Old 06-04-2011, 07:31 PM   #1
bobsurvives's Avatar
Need help!
Ok so, when I first bought my car I don't know what kind of radiator it had installed it had a fluidyne radiator and I wasn't to smart and didn't notice a coolant leak let the car run dry and it cracked the radiator. Car did not overheat and still runs good.
Over the past six months I have gone through two radiators that leaked from the core in top left corner close to the hose, one was a mishimoto and one was another fluidyne. Recently with a fluidyne in my car right now I'm getting the same leak!
There is also coolant residue under the bottom pullie....
Everytime I come home from school if I pop the hood and carefully release the pressure in the resivour the radiator will not leak... I changed the radiator cap and I'm still having the problem. Any clue what could be the problem?
Could the intervals of my motor cause this reoccurrence?
bobsurvives is offline   Reply With Quote
Old 06-04-2011, 07:32 PM   #2
Correction I meant the internals of the motor
Old 06-04-2011, 08:39 PM   #3
Send a message via Skype™ to Texastboneking
Re: Need help!
might be suffering from electrolysis. flush the entire system with a radiator flush. then empty all the water. fill with just water and run till hot. empty all the water again. then put a 50 50 mix of coolant. preferably the long life coolant. it is less prone to electrolysis.
Texastboneking is offline   Reply With Quote
Old 06-05-2011, 05:16 AM   #4
onesickstang01's Avatar
Have you replace your cap? Sounds like it isnt venting and you are holdin pressure in the system. When you release the cap and the pressure inside it doesnt leak? Sounds like a cheap fix is possible
onesickstang01 is offline   Reply With Quote
Old 06-05-2011, 10:00 AM   #5
wereKEV's Avatar
Re: Need help!
Yeah I would try the flush and fill .
wereKEV is offline   Reply With Quote
Old 06-05-2011, 10:17 AM   #6
Ok, I'm gonna do the flush and fill Becus from what Texas is describing (Electrolysis) I looked it up an that seems to be the problem.
Yes I already replaced the cap and I've come home and left it on and go back and take it off they're isn't any pressure but since they're already is a small leak I understand why it would leak while it is still pressurized
Old 06-05-2011, 10:18 AM   #7
Do you have any idea what could have caused this problem?
Should I replace any other parts?
I'm already in the process of getting a new radiator with my warranty
Old 06-06-2011, 11:53 AM   #8
Re: Need help!
its just like a disease. you just have to get the ph right in the coolant. once you get it its hard to get rid of. you will have to flush a few times im sure. usually caused by not changing the coolant when it needs to be changed
Old 06-06-2011, 03:23 PM   #9
Ok, I'm gonna get one if those radiator flush kits and keep on re flushing all coolant and water then replace it. Do you think I should get one of those Zinc Anod
Old 06-06-2011, 11:37 PM   #10
No
Old 06-14-2011, 11:59 PM   #11
Redlsea's Avatar
Lol I've heard it a hundred times and it sounds like a headgasket over pressurizing the coolant system to me
Redlsea is offline   Reply With Quote
Old 06-15-2011, 05:30 AM   #12
It could be. But he never complained about high pressure in the system or about it running poorly
Old 06-15-2011, 09:42 AM   #13
wereKEV's Avatar
Re: Need help!
Let us know what it turns out to be the suspense is killing me.
04:24 AM
