clutch pedle - Mustang Evolution
Old 06-06-2011, 02:55 PM   #1
Supersnake4.6's Avatar
clutch pedle
Is like vibrating then when is neutral comming to a stop it get worse why is this happening
Supersnake4.6 is offline   Reply With Quote
Old 06-06-2011, 03:04 PM   #2
Greg687's Avatar
Region: New Mexico
Re: clutch pedle
worn clutch, or maybe misaligned clutch. Had this happen to a friends car... the previous mechanic was unable to get the upper transmission bolts to tighten. When the clutch wore it started vibrating while in neutral with the pedal up. I put in a new clutch (the clutch plate bolts were rubbing on the pressure plate) and it went away.
Greg687 is offline   Reply With Quote
Old 06-06-2011, 03:13 PM   #3
Re: clutch pedle
could be throwout bearing, does it make a chirping noise or just vibrations?
Old 06-07-2011, 11:12 AM   #4
It's just vibrating
Old 06-07-2011, 11:17 AM   #5
Re: clutch pedle
hmmm could be just the clutch cable or the input shaft sleeve that the throwout slides on, or the throw out starting to stick etc
Is my Clutch okay? blue-saleen Pre-2005 V6 Mustang 8 05-05-2011 05:02 PM
I think i need a new clutch SaturnMan8227 Pre-2005 V6 Mustang 11 01-31-2010 09:25 AM
clutch help guerrerosal Pre-2005 V6 Mustang 4 03-22-2009 11:19 AM
best clutch ? jedwards242000 Pre-2005 V6 Mustang 5 04-09-2005 03:21 PM
Clutch Murph00 Pre-2005 V6 Mustang 2 06-30-2004 04:00 PM
01:01 AM
