A/C Help! PLEASE ITS HOT - Mustang Evolution
Old 06-08-2011, 12:39 PM   #1
CodyNelson's Avatar
Region: West Virgina
So my A/C has decided it doesnt want to work. I have checked the fuses under the dash and all is well there however there is one under the hood that is missing. the fuse diagram says A/C press (compressor im guessing) but the weird thing is there is nothing for the fuse to connect to, its just an empty slot. Can any help?
Old 06-08-2011, 01:03 PM   #2
Send a message via Skype™ to Texastboneking
I wouldn't fret over the fuse spot. It obviously doesn't apply to your model or something. If the blower motor ain't working then it's most likely your blower motor resistor block that's bad.
Texastboneking is offline   Reply With Quote
Old 06-08-2011, 01:13 PM   #3
CodyNelson's Avatar
Re: A/C Help! PLEASE ITS HOT
the blower itself works. I just cant get cold air. I put free-on in but the compressor wont kick on
Old 06-08-2011, 01:17 PM   #4
Probably not enough freon. There is a min and max pressure where the ac won't work. If you went over or under the set pressures it won't work
Old 06-08-2011, 01:22 PM   #5
See if there is anything blocking your condenser.
254S197 is offline   Reply With Quote
Old 06-08-2011, 01:25 PM   #6
CodyNelson's Avatar
Where would i check this?
Old 06-08-2011, 01:26 PM   #7
CodyNelson's Avatar
How do see how much pressure i have and how much should be in there?
Old 06-08-2011, 01:34 PM   #8
You will need a set of r134a high and low pressure gauges. Might be better off going to a shop.
Old 06-08-2011, 01:41 PM   #9
Your condenser is up front (radiator area) and I didn't pay attention to your car, but if it gas a shroud around the fan and it got damaged it would blow hot too
Old 06-08-2011, 01:49 PM   #10
CodyNelson's Avatar
i have the guages that you use to charge the AC with. How much pressure should I have on the high and low side?
Old 06-08-2011, 01:52 PM   #11
With the ac running. I would expect to see around 35 on low side and around 200 on high side. But outside temp plays a big part in pressure
Old 06-08-2011, 01:56 PM   #12
Google. R134a pressure temperature chart. And see what you get
Old 06-08-2011, 02:03 PM   #13
CodyNelson's Avatar
Okay thanks! And just thinking a step ahead here... If my pressures are okay whats next? Also, if the compressor wont kick on, will the high side even get a reading?
Old 06-08-2011, 02:07 PM   #14
If the compressor won't kick on. Both sides will read same pressure
Old 06-08-2011, 02:43 PM   #15
CodyNelson's Avatar
Okay good deal. Ill check that and get back with you
Old 06-10-2011, 02:04 PM   #16
CodyNelson's Avatar
Low pressure side reads 29 psi. Ford says that is fine. So what's next to check?
Old 06-11-2011, 09:26 AM   #17
onesickstang01's Avatar
Is the compressor clutch kickin in? You hould be abl to hear it? Is it clikcing on and off fast? If so its low on freon. Could be several things but i need more details
onesickstang01 is offline   Reply With Quote
Old 06-11-2011, 03:12 PM   #18
CodyNelson's Avatar
The compressor isnt kicking on at all. What kind of details? I'll tell ya anything I can
Old 06-11-2011, 03:27 PM   #19
Alright still many things that it could be. Ac control panel, ccrm, or compressor itself. Maybe high or low pressure switch as well. Takes a lot of testing
Old 06-11-2011, 03:32 PM   #20
CodyNelson's Avatar
Wonderful....any suggestions of where to start and how to test it?
Old 06-15-2011, 12:52 AM   #21
Redlsea's Avatar
Hey I'm a mechanic I would try spinning the compressor by hand I've seen where the compressor seizes but doesn't tear the belt off . If it doesn't turn check for power at the compressor if there is power seized compressor is the culprit
Redlsea is offline   Reply With Quote
Old 06-15-2011, 06:36 AM   #22
If the compressor was seized and the clutch was engaging we have two scenarios. One the belt would squeal and smoke like hell. Or two. The car would die. I believe his problem lies elswere
Old 06-15-2011, 08:17 AM   #23
my 2001 had an issue where the air would blow but it would get hot, it ended up being some little sensor or something that went bad. I wish I could remember what it was but this was a long time ago
I wonder if a scan would show any codes?
Old 06-15-2011, 08:18 AM   #24
Nope. Scan won't. And the sensor was most Likely a low pressure switch
Old 06-15-2011, 08:19 AM   #25
yea sounds familiar
Old 06-15-2011, 08:21 AM   #26
Could be his problem too. I'm waiting for him to call me
Old 06-15-2011, 10:37 AM   #27
Greg687's Avatar
Region: New Mexico
low pressure switch is usually on the receiver/dryer. You can disconnect the plug from the switch and short the connections in the plug to see if the clutch engages. If it does, then it's the switch, which means he will lose his a/c charge when he changes it
Greg687 is offline   Reply With Quote
Old 06-15-2011, 10:43 AM   #28
Not if you know how to change it fast
Old 06-17-2011, 03:56 PM   #29
Check the low pressure switch first by jumping (like said above), if that works then the low pressure switch is bad. When replacing it there is a schrader valve inder it that will keep the freon in so you will not loose any. If that is not it check the high pressure switch. If both switches are bad then check the CCRM located under the passenger fender. You can reach it from under the hood just next to the air filter box. Try tapping it while the car is running and the AC is on and see if the compressor kicks in. I did that with my 01 two years ago and is has worked ever since.
2001 GT AUTO, MAgnaflow Cat back, 70mm TB, K&N FIPK, C-springs, 275/40/17 all around
jjandascog is offline   Reply With Quote
« at tms | Cams?? »
Hot wheels Loraco The Bar 22 12-29-2010 05:47 PM
hot!!!!!!!!!!!! matthewh 1979-1995 Mustang GT 11 06-05-2008 10:38 AM
Will not start when hot SJLOGAN 1979-1995 Mustang GT 7 06-03-2007 10:02 AM
Now this is hot PureVenom Pictures and Videos 23 03-13-2007 08:43 AM
My house is hot WhiteStang99 The Bar 16 06-18-2004 05:53 PM
05:24 AM
